Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 11-21-2007, 07:41 PM   #1
tpyke
Sr. Member
tpyke is on a distinguished road
Default Base Plate with 1 1/2" versus 3 1/8" center
Is there any disadvantages to the 3 1/8" center?
...Or advantages to the 1 1/2"?
I figure if you can fit all bits in the 3 1/8", whats the point of the 1.5"??
tpyke is offline   Top - Reply with Quote
Old 11-21-2007, 08:04 PM   #2
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
You want the opening as small as possible for safety and control of the operation. If you were to use a 1/2" bit in a 3 1/8" opening, you could wind up with your stock trying to go down the hole. Not a good situation. If you were using a panel raising bit, you want to have the large opening to clear the size of the bit. That's why plates have inserts to adjust the size of the opening.
AxlMyk is online now   Top - Reply with Quote
Old 11-21-2007, 08:06 PM   #3
Mainewood
New Member
Mainewood is on a distinguished road
TPYKE,
For starters, you want to have as much flat surface around your cutter as possible. This helps reduce the chance of your project piece, depending on its size, from dipping into the open space around your cutter and messing up your work and possibly your fingers. Keeping the size of the hole as close to the cutter diameter as possible helps keep dust out of your router motor as well--just a couple of suggestions.
Happy Thanksgiving,
Mainewood (Ray)
Mainewood is offline   Top - Reply with Quote
Old 11-21-2007, 08:23 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi tpyke
It's more or less a safety issue ,it's true you can use just about any bit if the hole is 3 1/8" but do you realy want to...
Most of the time you would only see 66% of the hole at one time but that black hole can be dangerous if the part you are routing falls into that hole and jams the bit it can happen so quick...and you will not need to install a TP holder on your router cabinet...as a back up device...
The hole should only be just a bit bigger than the bit you are using,most don't use the brass inserts the norm they just use the 1 1/2" hole that's in the base plate and that's fine most of the time but the brass insert should be in place when you are using less say a 1/4" bit....again it's a safety issue and it's not worth the risk ,it's only some wood your working with...if it's worth doing it must be worth doing it safe..
http://www.leevalley.com/wood/page.a...000,51208&ap=1
http://www.harborfreight.com/cpi/cta...emnumber=95160
Multi-Sided Glue Joint Router Bits
http://www.mlcswoodworking.com/shops...ed_glue_anchor
http://woodworkersworld.net/router_b...ter_bits.shtml
http://www.sommerfeldtools.com/list.asp?d=47&p=1
http://cgi.ebay.com/1-PC-1-2-Shank-8...QQcmdZViewItem
base-plate-1-1-2-versus-3-1-8-center-6844.jpg  base-plate-1-1-2-versus-3-1-8-center-6847.jpg  base-plate-1-1-2-versus-3-1-8-center-6943.jpg  base-plate-1-1-2-versus-3-1-8-center-6842.jpg  base-plate-1-1-2-versus-3-1-8-center-7268.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-22-2007, 05:28 AM   #5
tpyke
Sr. Member
I'm surprised that no one sells a 3 1/8 insert with a 1 1/2" hole like Bob made....or do they?
Are the Oak park base plates counter bored to accept the brass inserts? If so, is it 3/16 or 3/4?
Old 11-22-2007, 05:47 AM   #6
RustyW
Forum Geek
RustyW's Avatar
First Name: Rusty
RustyW is on a distinguished road
tpyke, here is one of the cheapest out of many that are available. The smallest hole is recessed to accept Porter Cable style guides.
http://www.harborfreight.com/cpi/cta...emnumber=94331
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline   Top - Reply with Quote
Old 11-22-2007, 10:10 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi tpyke
The 3 1/8" hole size is a odd ball size, no one makes a insert that size that I know about and the 3 1/8" is a tapered hole that's why you see the 3 1/4" OD insert ring I made...just took it to the drum sander to get it to 3 1/4" size with true square sides..
I also like the PC type brass guides that Rusty W. talked about but I also like the 1 1/2' brass guides and I have a insert ring to take them on,,,they make it nice when you want to use a 1 1/2" bit with the insert in place unlike the PC type (1 3/16") brass guides that max out at 1" ID...
base-plate-1-1-2-versus-3-1-8-center-oak-park-plate.jpg  base-plate-1-1-2-versus-3-1-8-center-oak-park-plate-big.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Making your own sub base plate Mike Guide Bushings and Templates 9 08-18-2008 10:43 PM
Inlay Guide Bushing and base plate Doyle Portable Routing 3 06-07-2007 10:25 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 11:37 PM
Oak Park Phoenolic Base Plate needs 3 1/2" hole pmspirito Table-mounted Routing 5 03-23-2005 09:55 PM
Centering Base Plate -Sam- General Routing 15 01-04-2005 11:15 AM
