Rate This Thread - Making Mortises ?.
Thread Tools Display Modes
Old 11-27-2007, 11:23 AM   #1
Donzoid
New Member
Donzoid is on a distinguished road
Default Making Mortises ?
Hi, My first (real) post here. I'm fairly new at real woodworking. I'm going to make a small table and want to make mortises in the legs using a router table. I intend to clamp a guide piece and plunge the wood into the bit by holding on end down on the table and lowering the other to the table - like a hinge. Has anybody had any luck doing this ?
My next stop will be to buy a mortising machine. But this method seems like it will make cleaner mortises.
Donzoid is offline   Top - Reply with Quote
Old 11-27-2007, 11:48 AM   #2
Roefa
Forum Fanatic
Roefa's Avatar
Roefa is on a distinguished road
Send a message via Yahoo to Roefa
Hi Don -
Welcome to Router Forums!
Yes, the procedure you described is done often. I hope some of the real pros will add to my comments, but here's two cents: Be sure your fence is tall enough to provide a good surface to rotate down against. Put a piece of masking tape on your fence just above the width of the leg. Mark the position of both sides of the bit and put marks on the leg (or on tape on the leg) where you want the mortice to start and stop. Bring the leg down slowly and carefully between the marks and make your cut(s) using the marks to line up the beginning and end points.
You have found a great site with some really fine folks who are always willing to help you in any way they can. I hope you'll browse some of the threads to get an idea of the wide scope of things that are covered here. Log in regularly and join in. No doubt,
in time, you'll be able to contribute your ideas, too. It's a fun and informative group. Enjoy!
Roger
(Roefa)
Thinking outside the box? What box?
Roefa is offline   Top - Reply with Quote
Old 11-27-2007, 12:37 PM   #3
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
W e l c o m e !
Joe Lyddon is offline   Top - Reply with Quote
Old 11-27-2007, 12:52 PM   #4
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
That should work... better if you lay the board onto the bit in the middle of the mortise, then go side to side to your guidelines.
Also, to control the depth of cut, NOT doing the complete mortise in ONE pass...
Adjust your bit ht. to the desired depth.
Use some slotted pieces of 1/8" plywood over the table & bit, to raise the workpiece.
Make a cut.
Remove one piece, making room for another 1/8" cut.
Make a cut.
etc. until the last cut is without any spacers.
By doing that, it's easier on the bit, the wood, the router, and you will maintain the bit position to keep a clean cut pass after pass, etc.
Old 11-27-2007, 01:59 PM   #5
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Be sure to use a plunge bit for this operation. I plunge in the left side and move to the right. Unless you are using a very hard wood you should be able to use the 1/4" rule for cutting... remove no more than 1/4" per pass.
Old 11-27-2007, 02:25 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Don
Some router jobs are done better with the plunge router and this is one of them..
You can make a quick jig to do this easy job but you want the mortises to be dead on center and true...to the sides.
Here are just some of them
the 1st. is one Bob R. and Rick R. of the RWS came up with..
http://www.routerforums.com/jigs-fix...ge-router.html
http://www.routerforums.com/jigs-fixtures/
http://www.routerforums.com/search.php?searchid=166900
bobj3 is online now   Top - Reply with Quote
Old 11-27-2007, 02:28 PM   #7
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Don, welcome to the forum. The method you describe has been used many times as you see in the responses. I usually mark the start of the mortice on the fence using tape and I clamp a stop block to the out put side of the fence. I leave some room under the block to avoid having the cutting get stuck in between the stop and the work. In soft wood I'll take a 1/4" cut each time,and less in harder wood.
Good luck.. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 11-27-2007, 03:14 PM   #8
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Cool
I have seen Rick, for the most part, use the plunge method.
It seems to me that Bob, more often, uses the table method with his masking tape lines.
If you want to cut 1/4" portions, remove two of the 1/8" spacers, etc.
I think you're getting a good idea... it's what's more comfortable for you.
Old 11-27-2007, 04:01 PM   #9
template tom
Forum King
Don
I have found that making a simple jig is much quicker and safer than using the router table especially if you going to make at least 8 mortices this same type of jig can also be made to insert mortices in the rail then insert a 'Floating Tenon'
Tom
Setup for Puzzle Making rstermer Jigs and Fixtures 0 05-29-2008 04:23 PM
Making a vase part 1 chippypah Woodturning and Lathes 0 03-04-2008 02:23 AM
chopping mortises with bench chisels? reikimaster Tools and Woodworking 12 01-26-2008 12:12 PM
Wooden sign making tigger Introductions 5 08-16-2007 05:31 PM
template making wood reds_21 Tools and Woodworking 3 07-10-2005 08:45 AM
