| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Forum Geek | With my incra Ultra: ![]() Looks decent right? I’m not showing you the hammer it took to get this together… Or this: ![]() ![]() So I learned a few things tonight. 1) If a test cut with two dovetails is a “little tight” a row of tails is going to be VERY tight. I thought I had it perfect, but this is a live and learn situation. 2) If I find pieces of poplar that are far enough away from each other in color (heart wood vs. sap wood) I won’t have to stain of dye the corner posts (I was attempting a corner post dovetail box). Oh well, tomorrow I try again! |
| | #2 |
| Retired Moderator Supreme Forum King | Takes practice Nick but your doing great. Just need a nice slip fit... leave room for glue. Corey
| | #3 |
| Registered User Forum Geek | So what you are saying Corey is no hammer should be necessary? ![]() Thanks for the encouragement! I have plenty of wood left over to attempt a few sample corners. I'll keep this post going with my attempts. |
| | #4 | |
| Forum Contributer Supreme Forum King | Hi Nick Looking Good Here's a little tip,, the higher the bit the tighter the fit..with a stanard dovetail bit.. I think that's right it's late ![]() so to say drop your bit just a little bit.. Do it on a some test stock...2 or 3 dovetails will give you the fit.. It looks like you are pushing 1/2" deep , on your joints try 3/8" deep ![]() Just a note**** look real hard at the bottom of the dovetail , it looks a little round at the end, you maybe trying to use more of the cutter than you have or to say you are running out of the cutter at the bottom part of the dovetail.. ![]() but it maybe just the picture.... ============= Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 12-06-2007 at 11:52 PM. | |
| | #5 |
| Retired Moderator Supreme Forum King | Nick, I use a different jig but same result, to tight and you will mess them pretty little joints all up putting it together. You will get it down! Corey
| | #6 |
| Registered User Forum Geek | Heighten to Tighten, Lower to Loosen. Yup BJ! I think is was a little deceiving testing with 1 1/2 tails as the Incra instructions show. I'll make 3-4 next time to test the fit. It's ok, it's cold here in NJ, we need the firewood ![]() |
| | #7 |
| Registered User Forum Geek | BJ this is a 7.5 deg 1/4" dovetail bit. I had it set at aprox 1/4" depth. I just ran down and checked the bit package. It has a 5/16" depth of cut. Any distortion might have been from the hammering ![]() Last edited by Nickbee; 12-07-2007 at 12:00 AM. |
| | #8 |
| Registered User Forum Geek | Tonight’s effort: ![]() While not perfect, I at least got the bit height closer to where it should be. Maybe it was a little loose this time. I dyed the post with India Ink. Thanks for that recommendation Joe! This boosted my confidence high enough to go out and buy another piece of lumber to try 4 sides of a box next! I’ll report back when I have something together. |
| | #9 | |
| Forum Contributer Supreme Forum King | Hi Nickbee I'm amaze it's that black , can't wait till you use the trim bit and sand it off if it stays that black,,,if so I may just give it a shot...what are you going to use to seal it ?========== Quote:
| | #10 |
| Registered User Forum Geek | ya,, and that was with just one coat. We'll see what happens when I sand then use danish oil followed by poly. This is a test piece so I want to try all the steps on it. |
| My first attempt | harrysin | Woodturning and Lathes | 17 | 03-10-2008 07:55 AM |
| Dovetails - more or less - opinion | Donzoid | General Routing | 4 | 11-27-2007 02:02 PM |
| Rebated Dovetails | garryjc | Jigs and Fixtures | 3 | 10-15-2007 03:24 PM |
| Sliding dovetails for cabinet constuction? | Drugstore Cowboy | Tools and Woodworking | 18 | 07-08-2007 05:14 PM |
| Sliding Dovetails | scrollwolf | Table-mounted Routing | 2 | 09-12-2004 10:59 PM |
