Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 01-01-2008, 12:59 AM   #1
mntbighker
New Member
mntbighker is on a distinguished road
Default Router top plan in mind
I started to build a router stand for my cast iron Benchdog top yesterday and pitched the whole idea tonight. I have a new plan forming in my head and thought I would throw it out there for opinions. I have the 4 inch extension for it as well. My new plan is to use the top to build a pattern template. Then cut an MDF perimeter extension using the template. I figured I would use thread inserts around the inside perimeter in the MDF. Lay the whole mess on a flat surface and tighten the bolts. I considered adding a masonite layer over the MDF (or melamine) but I am hoping to route a grove for extra t-Track and if they have them a longer aluminum miter slot extrusion to extend the one the top comes with. I figure about 8 to 10 inches extension all the way round. I already have my cabinet design in mind and it will just be a bit wider and deeper. If this sounds like overkill, I have more in mind for this than just router table functions. I also plan to drill some holes in the MDF like the ones in my Festool Multi-Function table so some of those accessories will fit the MDF extension and I may even look into adding the perimeter aluminum extrusions. Festool sells them. I am matching the heights so the router table and Multi-function table can hypothetically be joined using Festool accessories.
--Mark
mntbighker is offline   Top - Reply with Quote
Old 01-01-2008, 07:25 AM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Mark, it all sounds very high tech. I am wondering if you have ever seen an episode of The Router Workshop? Bob and Rick's "Simple is better" methods won me over. I spend more time routing and less time trying to think of ways to improve my table.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
I think my old router nearly killed me! peacefrog General Routing 5 09-23-2007 07:11 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
