| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User New Member | hi everyone...I have a mastercraft 10A plunge router with table combo, but I'm having some issues when the router is attached to the table. I adjust the router depth so that the bit is as high as possible, but when attached to the table the bit still isn't high enough to give a proper cut. Only the top portion of the bit is up through the table and it won't go any higher. What am I missing? Thx Dave |
| | #2 |
| Forum Contributer Supreme Forum King | HI Dave It can be many things,, 1. the bit can be just a bit to deep in the collet. 2. you may still have the black base plate on the router. 3. the bit you are trying to use is a short one. 4. the pole stop is to far down and will not let the router move pass the stop point. 5. the turrit stop is not in the right place, it should be set at the lowest point ,the turrit is the device just under the pole stop to set the depth. http://www.shoptoit.ca/shop/product-...d_3297289.html ========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-01-2008 at 05:27 PM. |
| | #3 |
| Registered User New Member | Thanks! I'll check each of these |
| Insert Plate size and 11.5" handle spread; how to prevent problems | Ladd | Table-mounted Routing | 34 | 12-14-2007 02:08 PM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| Problem mounting Dewalt Router to Caftsman Table Saw | apollo2000 | General Routing | 8 | 05-22-2007 07:42 PM |
| Plunge router mounting on table | Bram | Table-mounted Routing | 6 | 04-04-2006 04:22 PM |
| Plunge router table problem | knott | Table-mounted Routing | 7 | 03-17-2006 02:41 PM |
