| | #1 |
| Registered User Forum Fanatic | I have tried numerous times to make the 45 degree sliding dovetails that you demonstrate on your video, the ones that appear to have dovetails on every side. I can not make them fit properly. I must not clearly understand the concept. Help!! Scrollwolf |
| | #2 |
| The Router Guys Forum King | You can get the joint, right? Just can't match the sides? If so then you have it, make the pieces larger than needed, cut the dovetail, assemble and joint the sides to match. To get the pieces to match perfectly. This is an operation that requires square material, size of material to match number of cuts, and perfectly aligned push blocks. Some luck and lots of pratice,
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #3 |
| Registered User Supreme Forum King | I'm not sure this is what you are talking about but this is "A Dovetail Joint Puzzle" Taken from: The Boy Mechanic: Volume 1, by Popular Mechanics way back in 1916. "A simple but very ingenious example in joinery is illustrated. In the finished piece, Fig. 1, the dovetail appears on each side of the square stick of wood, the illustration, of course, shows only two sides, the other two are identical. The joint is separable and each part is solid and of one piece. In making, take two pieces of wood, preferably of contrasting colors, such as cherry and walnut or mahogany and boxwood, about 1-1/2 in. square and of any length desired. Cut the dovetail on one end of each stick as shown in Fig. 2, drive together and then plane off the triangular corners marked A. The end of each piece after the dovetails are cut appear as shown in Fig. 3, the lines marking the path of the dovetail through the stick." See attachment for more details Ed |
| Dovetails - more or less - opinion | Donzoid | General Routing | 4 | 11-27-2007 01:02 PM |
| sliding dovetails on long boards | Neanderthal | Portable Routing | 5 | 09-21-2007 08:42 AM |
| Wall Shelf w/ Sliding Dovetails | Joe Lyddon | Show N' Tell | 45 | 08-15-2007 08:25 PM |
| Sliding dovetails for cabinet constuction? | Drugstore Cowboy | Tools and Woodworking | 18 | 07-08-2007 04:14 PM |
| Using sliding dovetails as drawer slide/guides. | rzaccone | General Routing | 4 | 01-11-2007 10:23 PM |
