| | #1 |
| Registered User New Member | Has anyone had success using a drawer lock bit on half inch Baltic birch? It does fine going with the grain, but creates a lot of tear out going cross grain. By cross grain I mean in relation to the top veneer. I tried scoring, using painters tape, wetting the plywood and multiple shallow cuts. The bit is of good quality and new. I tried three different bits. All the bits do well in solid wood. Thank in advance, Tony |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Tony A clime cut works well for plywood with veneer on it,,, you didn't say if you are using a router table or a hand router... The clime is just the wrong way to pulling the router or push the stock by the bit but you should not take more that 1/4" max in each pass.. It will push the veneer back into the plywood unlike the norm that pulls the veneer out and away from the plywood....it will act as a chip breaker in the clime cut way but you must hang on to the stock or the router because it running backwards from the norm. =========
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ |
| | #3 |
| Registered User New Member | I was going to bed, but ran out to the shop instead. It worked like a charm. This is the method I use to rout crisp rabbets and it did not occur to me to use it to rout drawer locks. By the way, I use a router table for these joints. All smiles now, Tony |
| | #4 | |
| Forum Contributer Supreme Forum King | You'er Welcome Tony Sometimes doing things backwards works ![]() ======= Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ | |
| Freud Drawer Lock Bit 99-240 | RobW | Router Bits - Types and Usage | 3 | 05-08-2008 01:01 PM |
| EZ Link | DougO | Introductions | 2 | 03-09-2006 12:52 PM |
| Drawer joints - Box vs. Dovetail vs. ??? | ChevyNomad | General Routing | 2 | 01-14-2005 10:20 AM |
| Making a Zero Clearance Fence for Drawer Lock Bit | gerrym526 | Table-mounted Routing | 3 | 12-16-2004 12:43 PM |
