Rate This Thread - Rounded Mortise & Squared Tenons?.
Thread Tools Display Modes
Old 01-15-2008, 04:57 AM   #11
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
I'm with Ken and Tony, loose tennons are so easy.
Harry
harrysin is offline   Top - Reply with Quote
Old 01-15-2008, 06:30 AM   #12
Nickbee
Forum Geek
Nickbee's Avatar
Nickbee is on a distinguished road
Here’s a silly question about loose tenons.
When using round over bits to make the tenon stock do you half the diameter of the bit you used to make the mortise?
Example, if you used a ¼” straight bit to make the mortise you use a 1/8” round over on the tenon stock?
Thanks!
Nickbee is offline   Top - Reply with Quote
Old 01-15-2008, 07:49 AM   #13
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Nope, the same diameter or a 1/4" bullnose cutter.
Harry
Old 01-15-2008, 07:52 AM   #14
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Nickbee
I use a bead bit to make my floating tenons,,,(1/4",3/8",1/2" ) I use hardwood 24" long stock the norm..
Just pop in one of your bead bits ( You may have many bead bits, just don't know you do) many bits have the bead profile cut in them,,,along with other profiles,,,on the same bit..
Just popin the bit in the router table, run one side and then flip it over and run the other side, I use 2" ,2 1/2", 3" wide stock,, do one side and then do the other side then rack them up and rap masking tape round the tenon stock, then when you need some tetons just cut off what you need,,,,I make all the sizes at one time and all about 24" long or about that...just like dowel rod stock,,,,I made a stand out of some 4" hvy.wall PCV pipe and about 16" tall, mounted in a flat board with a ring in it, to hold the same size PVC pipe..it now holds the dowel rods and the teton stock..
That reminds me I need to make some more ,getting low on the backup stock.
I also cut some off and put them in plastic jars,,,,so I have some ready to go quick and easy...the Boss buys stuff from Cosco/Sams that come in the larage plastic jars and just about always I nail them when I see them and put the stuff in a plastic bag and take the jar LOL LOL ...
bobj3 is online now   Top - Reply with Quote
Old 01-15-2008, 07:58 AM   #15
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Bullnose, bead bit, the same I think. You're method Bj. is the same as mine and Tom's.
Harry
Old 01-16-2008, 08:11 PM   #16
paulleveille
New Member
paulleveille is on a distinguished road
a good chiseling never hurt a man.HE HE .I plan on doing through mortises on a curoi stand im making for the wife.Chiseling all the corners.heart pine wood so hope its not going to be to bad.
paulleveille is offline   Top - Reply with Quote
Tenons on the Router Table rstermer Table-mounted Routing 12 04-24-2008 09:41 AM
Multiple Hinge Mortise Jig FES Jigs and Fixtures 10 11-12-2007 02:56 PM
My mortise jig guyos Jigs and Fixtures 3 10-04-2007 10:07 PM
Rolling Mortise Jig - the test simplenik Table-mounted Routing 9 07-23-2007 10:54 AM
Rounded tenons, how to? Cubbie General Routing 22 03-01-2005 04:54 PM
