| | #1 |
| Registered User Forum Geek | I’m a newbie when it comes to joints. I’ve set up my router table and I’m having a good time learning about its capabilities (and limitations). A few projects I’m looking to do require mortise and tenon joints. My plan was to use my router table and fense to “plunge” cut the mortises with a straight up cut bit. Then use my coping sled and a slot cutter to cut the tenons. This is going to leave me with rounded mortises and squared off tenons. So my options as I see it are: 1) Use a chisel to square up the mortise (ick) 2) Use a rasp, sandpaper, something to round off the tenon (not as bad) 3) Just make the mortise slightly longer so the square tenon will fit (easiest option) Now I realize that that option #3 would be the worse case for strength, but I’m wondering if that’s an acceptable way to do things. I guess it would also depend on how much stress the joint is going to get. |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi Nickbee A over size joint is a weak joint,,, ![]() If the joint moves the glue will fail ...and it will come apart..in time.. ![]() Just square the holes out...with a tool that's made just for that.. Corner Mortising Chisel , Cabinetmaker Chisel http://www.mlcswoodworking.com/shops.../routacc3.html ===== Sometimes you can use this type, 2ea. for 10.oo bucks, if the hole is not to deep...or you can take one apart and use it without the corner brace...if you buy that item you get 2ea. for the price of one.. http://www.rockler.com/product.cfm?p...quare%20chisel ========== http://www.mlcswoodworking.com/shops.../cornchis.html ============= Or you can play with it and just sand it down until it fits.. ![]() ============= Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 01-14-2008 at 03:28 PM. | |
| | #3 |
| Registered User Forum Geek | great BJ, you are going to make me buy more tools. Thanks ![]() |
| | #4 |
| Forum Contributer Supreme Forum King | Hi Nickbee hahahahahahaha, the right tool for the right job, it makes the job come out just the way you want it to and it makes it fun on top of that..if it's not fun you will not do it again and I'm almost sure you can't wait to get that slot cutter in the router and play with it one more time.....======= ====
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ |
| | #5 |
| Registered User Supreme Forum King | Have you tried or considered a "loose tenon & mortise"? Cut the mortises as norm with the router but, the tenon, you use a round-over bit to make the edge match the mortise.
__________________ Ken (On temporary leave of abscense) "A VETERAN" "Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #6 |
| Registered User Forum Geek | Hey Hamlin. I have not tried either a loose or integral joint yet. But I have done rails and stiles. Figured I'll get around to trying all the kind of joints eventually. Bj, you hit the nail on the head! |
| | #7 |
| Forum Contributer Supreme Forum King | Hi NickBee OR You can spend some more money and get Beadlock When it comes to woodworking equipment I can empty your pockets quick ![]() 3/8'' Beadlock Basic Starter Kit http://www.rockler.com/product.cfm?p...=loose%20tenon Sometimes called a floating tenons... ==============
| | #8 |
| Registered User New Member | Had trouble with the Bead Lock. I could not get a mortise 90 degrees to the face of the rail. It turned out the face of the jig was not milled flat. After three replacement having the same problem I gave up. The jig plates are stamped and can easily be bent. Maybe if they were milled? Tony |
| | #9 |
| Registered User New Member | PS I use loose tendons, they work well. I also use Dowlemax: very easy and very accurate, but also very expensive. More tools to buy. Tony |
| | #10 | |
| Banned Supreme Forum King | Quote:
Six of one and a Half dozen of the other... IMHO, pick the easiest between #1 & 2 (forget #3) and do it. I, personally, round the tenons. Last edited by Joe Lyddon; 01-14-2008 at 10:30 PM. | |
| Tenons on the Router Table | rstermer | Table-mounted Routing | 12 | 04-24-2008 09:41 AM |
| Multiple Hinge Mortise Jig | FES | Jigs and Fixtures | 10 | 11-12-2007 02:56 PM |
| My mortise jig | guyos | Jigs and Fixtures | 3 | 10-04-2007 10:07 PM |
| Rolling Mortise Jig - the test | simplenik | Table-mounted Routing | 9 | 07-23-2007 10:54 AM |
| Rounded tenons, how to? | Cubbie | General Routing | 22 | 03-01-2005 04:54 PM |
