Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 01-16-2008, 04:46 PM   #11
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Ken
Well because the knuckles are only 1/4" O.D. that word be a hard one ,, I think I'm going to take some 3/8" OD brass rod and drill some 1/16" holes in them on the lathe on dead center , that way they will fit the jig and with a 1/16" thick spacer to hold the hinge plate just right it may work...
The drill bushing they are using on the jig are held in place with Allen set screws so I can remove them and place in the smaller ones and move them just a bit to get the 1/4" wide knucles to fit it just right.. I think..
Well I off to try the jig out
Originally Posted by Hamlin
Hi Bob,
I understand that problem. Not sure if this would work. What about 1/4" ID pipe, would only have to do some notching. Would be a pain to do though. But, it is a possibility.
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-16-2008, 05:09 PM   #12
George II
Forum Fanatic
First Name: George
George II is on a distinguished road
OK Bob I understand your thought process. My thing was bending the wire as being a real pain in the "roid" area. The glue dop will work but sometymes it will not hold to stainless steel. To help with the sticking ability you might try roughing the stainless area with sand paper to help with adhesion.
Good luck as I know you will do well.
Best Regards..
Originally Posted by bobj3
Hi George II
I think I'm going to use THICK super glue to terminate the ends, one small dot should do the trick I think...
If I cut the hinge right ,I should have one part of the knuckle on both ends that will take on the glue and the end of the pin...
I use super glue all the time on wood projects and it holds very well ..and sets up in about 5 sec. or less...with the spray.. (AceTone)
The jig comes with a #30 bit (.128 in dia.) that's 6" long and I did order one #30, 12" long also...
I do have a long #40 bit for the stainless wire that should work..
And I'm looking at it now... great little jig...
"Please keep us advised on your work in this matter" = will do
George II is offline   Top - Reply with Quote
Old 01-16-2008, 05:27 PM   #13
Nickbee
Forum Geek
Nickbee's Avatar
Nickbee is on a distinguished road
Bj, did the jig come in yet?
Nickbee is offline   Top - Reply with Quote
Old 01-16-2008, 06:15 PM   #14
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Nickbee
Yep sure did
here's some snapshots,,
Jewelry BoxDirect
http://www.jewelryboxdirect.com/?gcl...FQiaPAodZU-LIA
hinge pins & finials
http://www.hardwaresource.com/searchresults.asp
http://www.hardwaresource.com/Store_...cts.asp?Cat=84
http://www.hardwaresource.com/Store_...l3.asp?Cat=691
wooden-hinges-8103.jpg  wooden-hinges-8104.jpg  wooden-hinges-8105.jpg  wooden-hinges-8106.jpg  wooden-hinges-8107.jpg
wooden-hinges-8108.jpg  wooden-hinges-8109.jpg  wooden-hinges-8110.jpg  wooden-hinges-8112.jpg  wooden-hinges-8113.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-16-2008, 06:57 PM   #15
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi George II
sanding the pin,,,Will do,,,thanks,, do they make something better than super glue ....? for stainless ..I was thinking about drilling a small hole for a cross pin, but stainless can be a pain to drill,,,I have drill bits bit that I can use in 1/16" wire but it's tricky to drill....my old eyes are not the same when I did it b/4..
At one time I drilled tons of fastners for safety wire & nylock buttons..it's tricky most of the time...they do like to break the bits..and stainless is one of the hard ones to drill ( 18.8 stuff )
Best Regards..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-16-2008, 10:15 PM   #16
Nickbee
Forum Geek
Nickbee's Avatar
Hi Nickbee
Yep sure did D:
Looks great Bj, thanks for sharing! That puppy is in my future
Old 01-16-2008, 10:50 PM   #17
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
Now, I'm jealous. Gonna hafta get one myself. lol
Just a thought about the stainless wire, they make screws small enough to match 1/8" bit, just cut the wire short, glue in the screws on the end.
Ken
"A VETERAN"
Old 01-16-2008, 10:55 PM   #18
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks Nickbee
It's fun making stuff out of wood that's not the norm
Wooden hinges are neat and easy to make now that I have made one..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-16-2008, 11:02 PM   #19
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Very cool Bj!!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 01-16-2008, 11:14 PM   #20
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks Corey
Most of the time Hinges are like looking at a sore thump sticking out of a nice cabinet/box but this type should make it a be more unique/one of a kind....
Plus it's fun to make
Originally Posted by challagan
Very cool Bj!!
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
New hinges Hamlin Table-mounted Routing 7 06-06-2008 05:36 PM
Wooden Hinges part duex Hamlin Table-mounted Routing 16 02-26-2008 09:53 PM
Help with Hinges nzgeordie Tools and Woodworking 6 12-07-2007 08:32 AM
vers SMALL hinges reds_21 Tools and Woodworking 1 08-13-2005 09:51 PM
Wooden Locks Dr.Zook Lobby 2 10-16-2004 01:25 AM
