Rate This Thread - Wooden Hinges.
Thread Tools Display Modes
Old 01-15-2008, 12:58 PM   #1
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Default Wooden Hinges
Wooden Hinges made on the router table,,,,
Using 3 bits, 3/8" bead bit, 1 1/8" wide bit, 3/8" wide bit, and the Oak-Park box joint jig.
Still in the hold pattern waiting for the Incra Hinge jig to drill the holes out for the brass hinge pin...
Push Block for the Oak-Park box jigs
http://www.routerforums.com/jigs-fix...ush-block.html
hingecrafter jig
http://www.woodpeck.com/hingecrafter.html
Oak-Park Spacer Fence Set (1/4", 3/8" & 1/2")
http://us.oak-park.com/catalogue.htm...product=SF1030
http://us.oak-park.com/catalogue.html?list=boxj--
see the link below for more pictures ▼
http://www.routerforums.com/64184-post14.html
wooden-hinges-8077.jpg  wooden-hinges-8080.jpg  wooden-hinges-8090.jpg  wooden-hinges-8091.jpg  wooden-hinges-8092.jpg
wooden-hinges-8093.jpg  wooden-hinges-8094.jpg  wooden-hinges-8095.jpg  wooden-hinges-8096.jpg  wooden-hinges-8097.jpg
wooden-hinges-8098.jpg  wooden-hinges-8099.jpg  wooden-hinges-8100.jpg  wooden-hinges-8101.jpg  wooden-hinges-8102.jpg
Old 01-15-2008, 08:27 PM   #2
Hamlin
Supreme Forum King
Looks like this might be the cheaper way to go for hinges.
You should be getting the jig any time now, correct?
Ken
(On temporary leave of abscense)
"A VETERAN"
"Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown
Old 01-15-2008, 08:41 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Ken
Well I did cancel the order with Rockler (they had it setup to ship on the 18th) and got it on the way from Woodpecker should be on my door step Fri, the 18th...
Plus a I saved 10.oo bucks buying from WoodPecker but I blew that on a 12" long drill bit.. LOL .. so in away the bit only cost 10.oo bucks...
Old 01-15-2008, 10:57 PM   #4
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Wow Bj, that looks way cool! Awesome work. Going to build a special box for these Your making me jealous bud! Just got on today for the first time. Work is crazy busy right now. Thanks for all the pics! Will you mortise these into a box back like a regular hinge?
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 01-15-2008, 11:32 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks Corey
" mortise these into a box "
I think so, I'm going to try it both ways to see how it looks,, trying to come up with a way to make them 1/4" , they show 3/8" small, but maybe I get get in done in the 1/4" size for small boxes (lids) , maybe the double hinge type will get it done,just playing with now...
Old 01-16-2008, 10:10 AM   #6
Hamlin
Supreme Forum King
Should be simple enough, I'd think. You only need the 1/4" bull nose. I'm sure you already have it though.
Ken
"A VETERAN"
Old 01-16-2008, 10:29 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Ken
The 1/4" one is going to be tricky,,,using a 1/4" bull nose, the 1/8" pin is a bit big so it looks like a 1/16" pin may do the trick...I have some stainless steel wire that I'm going to try, but drilling the holes that's the hard part....I have one or two aircraft drill bits (4" long) that may do the job but getting on center ,well that's the hard part...I may need to pick up some drill bushing guides that will fit the jig..
The hinge will only 1/4" thick when it's close,, that make the hinge parts only 1/8" thick, and to drill a 1/16" down the center ,well it's like making clock parts and then keeping the hole true for long 1 1/4" long, well , it may not be worth it.. but I do like a challenge...now and then,,, LOL
Old 01-16-2008, 02:27 PM   #8
George II
Forum Fanatic
George II is on a distinguished road
Bob,
Are you going to use hinge pin wire for the hinge pivot? If so how are you going to terminate the ends to keep them from sliding out? From my experience working in aircraft I know this can be a real bitch unless you have room at the ends to bow them.
The extension bits, I know also from experience that the small sizes you will need would probably be around # 30 or # 40.
You have tweaked my idea bush from a brain fart into a creative mode. Please keep us advised on your work in this matter..
Thanx,
George II
Originally Posted by bobj3
Hi Ken
George II is offline   Top - Reply with Quote
Old 01-16-2008, 03:28 PM   #9
Hamlin
Supreme Forum King
Hi Bob,
I understand that problem. Not sure if this would work. What about 1/4" ID pipe, would only have to do some notching. Would be a pain to do though. But, it is a possibility.
Ken
"A VETERAN"
Old 01-16-2008, 03:32 PM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi George II
I think I'm going to use THICK super glue to terminate the ends, one small dot should do the trick I think...
If I cut the hinge right ,I should have one part of the knuckle on both ends that will take on the glue and the end of the pin...
I use super glue all the time on wood projects and it holds very well ..and sets up in about 5 sec. or less...with the spray.. (AceTone)
The jig comes with a #30 bit (.128 in dia.) that's 6" long and I did order one #30, 12" long also...
I do have a long #40 bit for the stainless wire that should work..
And I'm looking at it now... great little jig...
"Please keep us advised on your work in this matter" = will do
Originally Posted by George II
Bob,
Thanx,
George II
New hinges Hamlin Table-mounted Routing 7 06-06-2008 04:36 PM
Wooden Hinges part duex Hamlin Table-mounted Routing 16 02-26-2008 08:53 PM
Help with Hinges nzgeordie Tools and Woodworking 6 12-07-2007 07:32 AM
vers SMALL hinges reds_21 Tools and Woodworking 1 08-13-2005 08:51 PM
Wooden Locks Dr.Zook Lobby 2 10-16-2004 12:25 AM
