| | #1 |
| Registered User New Member | I am building a miter table and was wondering what type of track I should be installing on the top, running parallel to the fence. A friend insists that I should install a miter channel, so that I can use a miter to make sure I'm perpendicular to the fence when pushing stock through. I notice that most tables have a t-track so that you can attach a feather board to keep your piece close and tight to the fence. I'm not sure how you would use a feather board with a miter channel. What's the best way to go here? Also, what is the recommended distance between the channel and the router bit and about where the template should be installed? I'm hoping to build a table that is 18" deep X 24" long. Thanks for any help and suggestions on this. Paul |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi Paul I would suggest using the tee-track stuff, in both sizes...install them right at the end of the table (front side) they work great to hold fixtures but not for sleds,,, it's a pain to get them to line up with the fence.. The fence will do all the work for you,,because the router is a one point cutting point unlike a table saw... If you try and use a tee-track you have 3 points to line up and one will always be off just a bit..(it's geometry thing) "what is the recommended distance between the channel and the router bit and about where the template should be installed?" I would suggest put the mounting plate in the center of the top but to the front just a bit. 18" wide top,, the bit would be 8" from the front and 10" from the back,this will give you room to flip the fence around to do wide stock on the back side so to speak,,,and most of the feather boards will work from the front side..plus put in a tee-slot in the fence, this will let you use the fence to hang the feather boards on the fence..or bit guard.. The 10" on the back side will let you add a Incra setup or the Oak-Park jigs down the road..if you want.. ========= Quote:
__________________ Bj | |
| | #3 |
| Senior Moderator Supreme Forum King | Paul, the Router Workshop method would be no tracks at all. Sleds or work pieces are simply guided by the fence. Everything keys off the bit so there is less set up. Once you go with a miter or T track you must make sure the fence is square to the track, an additional step. Either way works just fine and the choice is yours.
__________________ Mike |
| | #4 |
| Registered User New Member | Thanks for the reply, but I'm confused. What do you mean by "tee-track stuff, in both sizes"? Are you suggesting two tracks, one a T (narrow)and the other slot (wider)? My understanding is a T track holds t-slot bolts and a miter channel holds something like an Incra miter. They are different sizes, and the miter channel has straight sides. Paul |
| | #5 | |
| Registered User Forum Geek | Quote:
Be sure you settle on one brand and stick with it. Incra T-tracks are designed to fit standard 1/4-20 hex head bolts. Some other tracks (such as the blue track sold by Rockler) are designed to use the specialized T-track bolts. So -- knobs etc. made for one will not fit the other without some grinding. Just something I learned the hard way.
__________________ The one who says it can't be done -- Should avoid interrupting the person doing it. | |
| | #6 | |
| Forum Contributer Supreme Forum King | Hi Drugstore Cowboy Here'a a little tip to fix that error.. Pickup some square nuts,,10-24,1/4-20 and some of the 5/16-18 will fit the slot T-slots, also threaded tee-nuts,then just clip off the 3 little spikes. Plus some 5/16-18 x 4" full thread toggle bolts when you need to use the stud type bolt,just grind the sides of the head just a little bit to plut on the flats on the head and they will side right in the T-slots,works great for the T-slots in the fence also.. ========== Quote:
__________________ Bj Last edited by bobj3; 01-23-2008 at 09:34 AM. | |
| | #7 | |
and even easier -- I started to just grind the sides of the t-track bolts so they would fit in the Incra slots. But - this time I was lazier than I was cheap - Just bought some Incra knobs to go with the Incra track. Held on to the 'Rockler' knobs though to use in shop-made jigs etc.
| | #8 |
| Senior Moderator Supreme Forum King | Paul, track comes in different styles and sizes. One popular option has t-track and a miter slot in one piece about an inch wide. This lets you use both with ease. By the way, you can pay for expensive T-bolts at a woodworking store or you can buy toilet bolts. There are finger boards that will work in a miter slot so look through all the options before making a purchase.
| Baffled by Woodworking Channel!!? | Birch | Tools and Woodworking | 15 | 08-24-2008 03:25 PM |
| Perfect 22.5 degree miter | Kristin D | Tools and Woodworking | 11 | 02-26-2008 05:59 PM |
| bit for Jack Miter molding joint | tshaw47 | Router Bits - Types and Usage | 3 | 09-11-2007 08:01 PM |
| Table Saw Miter Guage Fence | dunmovn | Tools and Woodworking | 3 | 12-11-2006 02:21 PM |
| miter gauge for table saw, help | delroy33 | Tools and Woodworking | 3 | 10-27-2004 04:01 PM |
