Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 01-27-2008, 04:36 PM   #1
RAKESS
Jr. Member
RAKESS's Avatar
RAKESS is on a distinguished road
Default Best Router for Cutting Slots - Slat Wall
I'm new here and this also shows up in the introduction forum, but thought it might be better placed here.
I'm about to begin on a project to cut some slat wall panels (slot wall, t-track, if you prefer) from 3/4" stock. The plan is to use it for garage and closet storage hangers.
BTW, the accessories are very inexpensive. It seems only the panels cost an arm and a leg. So, why not spend the money on a router?
I've found a good slot cutting bit. Cutter length is 35/64". Diameter is 1 3/8" and the shank diameter is 1/2".
Unless someone would like to take a shot at convincing me otherwise one of two Bosch routers make up my short list. Assuming the switch problems have been fixed, the 1617 plunge/fixed combo or the 1619.
Normally, I would go for the 2 1/4 hp version, but I'm concerned it won't handle the wide/lengthy slot cuts I need to make. As a result, I'm leaning toward the 1619.
Any advice/comment will be appreciated.
RAKESS is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
I think my old router nearly killed me! peacefrog General Routing 5 09-23-2007 07:11 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
