Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 02-22-2008, 10:11 PM   #1
kylawyer
New Member
kylawyer is on a distinguished road
Default Question on raised panels
I am new here. Just bought a Bosch 1617evspk and 1171 table. I am building a built in cabinet for my seemingly never ending basement finishing project.
I decided I wanted to make some raised panel doors. When I went to buy the router, they had 2 different raised panel bits. A Skil raised panel bit set that was very inexpensive and an expensive rail and stile and raised panel bit for bosch.
Since I was getting a bosech router, and because the Skil bit set looked a bit cheap, I went with the bosch bits.
Here is my concern. The bosch panel bit is 3.5 inches in diameter. I asked the guy at the tool counter if this router would swing it. He said sure as long as you run it slow and do it little by little and don't try and cut it in one pass.
I am still a bit concerned after looking at the sheer diameter of the bit. So I guess my questions is, will this router swing and effectively swing this bit and work? Or should i go back and get the cheaper, and mch small Skil bit?
kylawyer is offline   Top - Reply with Quote
Old 02-22-2008, 10:28 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi kylawyer
The guy behind the counter was telling you the truth , you will need to take small cuts (3 most of the time) and turn the speed down on the router to run the BIG bits, that's true for most bits over 2 1/2" you'er pulling off alot of wood ..
Now that you have the Bosch bits keep them I'm sure you will like them.
Here's link you may want to check out if you are making doors and panels
http://www.routerforums.com/jigs-fix...hinge-jig.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 02-23-2008, 01:59 PM   #3
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi: KYLAWYER welcome to the forum. The bosch bit will do fine, if you take it in three or more passes. The router should be slowed down to 10,000-12,000 rpm. you should also use a push stick that is able to also hold the stock down to the table. I have made some raised panels that required three passes. I usually do two passes with a fairly heavy cut and leave the last pass as a very light cut, it cleans up real well.
Hope this helps..Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 03-08-2008, 07:25 PM   #4
Andy4810
New Member
Andy4810 is on a distinguished road
Default cabinet door construction
I have my router table set up, have 3 bits for making panel doors. I've made sample cuts with each bit. My confusion is this: Between the rails and the stiles - do you use both when making raised panels. Or just one to mate with the machine panel. I can see where you could make a frame of four boards milled with a stile and mitre the corners and that would hold the panel. But is there a way to make a square frame so I could use a raised panel.
Looking for help or if someone has a sketch of these two types of panel doors, mitred and squared. The kit I bought for making paneled doors, contained 3 bits, stile, rail and panel. So do I use all three?
Andy4810 is offline   Top - Reply with Quote
Old 03-08-2008, 07:37 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Andy
The short answer would be yes, you will need to use all 3 bits that are in the" set "
Start with the cope bit then the bead bit then the panel bit..
Make a test door b/4 you use the good stock..
The cope bit is the one with the bearing in the middle of the bit and is use it on the end grain of the boards.
Almost all the sets come with bearning use them to setup the bits...
http://www.mlcswoodworking.com/shops...ges/video.html
http://www.sommerfeldtools.com/departments.asp?dept=4
http://www.mlcswoodworking.com/shops.../instruct.html
http://www.mlcswoodworking.com/shops.../ec080123.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-08-2008, 11:44 PM   #6
curiousgeorge
Supreme Forum King
curiousgeorge's Avatar
First Name: George
curiousgeorge is on a distinguished road
Maybe the chart below will help with choosing the correct speed for a bit size. You can print it and hang on the wall by your bench.
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile. I like to know who you are and where you are from. If you don't want me to know who you are, then I don't want to talk to you.
curiousgeorge is offline   Top - Reply with Quote
Is there quick fix for slightly loose fitting raised panels? tpyke General Routing 3 02-13-2008 08:59 PM
Question about raised panels tpyke General Routing 4 01-29-2008 02:40 PM
Router for raised panels Jtomwoods Table-mounted Routing 3 08-21-2006 01:59 PM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 10:47 AM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 01:56 PM
