Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 03-15-2008, 07:45 PM   #1
S Bolton
Forum Geek
S Bolton is on a distinguished road
Default Plastic laminate
Is there a trick to applying plastic laminate. I used the explosive Weldwood type glue because I heard that is good. I put it on both surfaces and waited until it was dry to the touch.
I used a J roller and rolled it a lot.
A month or two later, part of the laminate came up, making me unhappy.
Maybe I should have applied the two surfaces when the adhesive was a little wetter?
Steve Bolton
S Bolton is online now   Top - Reply with Quote
Old 03-15-2008, 07:53 PM   #2
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Steve, laminate should be dry to touch when you put them together. Might not have got enough glue on them.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 03-15-2008, 09:05 PM   #3
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Steve, as Corey has stated, dry to the touch is the norm. I'm not familiar with you're particular adhesive but assume that it is a "normal" contact adhesive. Clean, dry dust-free surfaces are of course essential using a liberal amount of adhesive well spread. I personally use the gel type contact adhesive, it lasts longer in the can and is far less messy to handle. Using dowels to centre the laminate and removing them one at a time as you press the laminate down makes for an accurate fit without air bubbles.
Harry
harrysin is offline   Top - Reply with Quote
Old 03-15-2008, 09:08 PM   #4
S Bolton
Forum Geek
Harry, do you have a brand mae for the gel type? I don't think I am familar with them.
Any suggestions as to the best contact cement? Oil based? Water based?
thank
sb
Old 03-15-2008, 09:15 PM   #5
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
thank
sb
This is what I use here in Australia, it's solvent based, I once tried water based contact adhesive and it was a dismal failure, no wonder they stopped making it!
Harry
Old 03-15-2008, 10:08 PM   #6
curiousgeorge
Supreme Forum King
curiousgeorge's Avatar
First Name: George
curiousgeorge is on a distinguished road
Steve, another thing that might hinder contact cement is temperature. If you were working with the temp. under a certain point the cement will not adhere correctly. I'm not sure what it is, but it should say on the can directions.
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile. I like to know who you are and where you are from. If you don't want me to know who you are, then I don't want to talk to you.
curiousgeorge is online now   Top - Reply with Quote
Old 03-16-2008, 01:51 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI Steve
Next time give this a trick a try,,sand the Plastic laminate with 60 grit sand paper,,,(besure to blow off the dust b/4 you put on the glue or use a tack rag) because it's plastic it's sealed in a way, by sanding the laminate it will give it a place to hold on too. (cross hatch sanding works best or in a circle )
I just about always use 3M #77 or #90 ,it's in a spray can and is easy to put down...no roller/brush needed just a J-roller once the parts are in place,plus I don't wait till it's tacky ,this gives me time to move the stock around and line it up.
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-16-2008, 09:43 AM   #8
S Bolton
Forum Geek
Will do. Makes sense. How warm does it have to be in my shop? I use the explosive stuff because I hear it is better? True?
SB
Old 03-16-2008, 09:45 AM   #9
jerrymayfield
Forum Geek
Many years ago I installed a good deal of plastic laminate using contact cement. What worked best for me was to apply the adhesive to both surfaces,allow to dry and then apply a second coat. Never had any problems after doing it that way,several before.
Regards
Jerry
Old 03-16-2008, 10:17 AM   #10
S Bolton
Forum Geek
After you apply the second coat, how long do you wait?
sb
laminate counter top lyoncub Starting Off 2 01-10-2008 11:57 PM
glue for plastic laminate S Bolton Table-mounted Routing 8 09-29-2007 01:05 PM
What Router to buy (cutting plastic) stevegriswold General Routing 1 07-03-2005 01:56 PM
Plastic Drick General Routing 2 03-06-2005 10:53 AM
