| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Member | I am having a problem template routing a small piece. I am using a Shear Angle Flush Trim Bit from MLCS that I just got, so it's clean and nice and sharp, and am doing this on my router table. I trace the template pattern, cut the poplar stock to approximately 1/16" outside the line, then attach the template with double-stick tape. I route from right-to-left and, as I'm feeding the stock, it begins to chatter, then will catch and try to pull it from my fingers, gouging and tearing the wood - it actually tears pieces out along the grain. This is the second bit that I have attempted this with - I figured that the first was a cheaper bit and had been used a bit so it might be dull. But the new bit made no difference. It's a little nerve wracking when the stock catches, since the piece is so small and my fingers are close, but not near, the spinning router - that's why I'm using a bottom-bearing trim bit - the template is thus between my fingers and the spinning bit. Jim |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Jim This would be my guess,, the bearing looks like it riding a bit low on the template and it slipped under/below the template in the corner when it started to go upgrain on the stock... This is what I would try once you have one end done flip it over and come in from the other end, this take two templates one on the top and one on the bottom. Also if you are making more than one used wider stock and then rip it on the table saw./band saw to the right size...after the router job... This will give you more to hang on to...and help keep it flat to the table.. You may need to sacrifice the botton edge of the template to get it to ride a bit higher on the template, set the bearing right on the upper 2/3 of the template or to say just below the top edge. ========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-20-2008 at 10:43 PM. |
| | #3 | |
| Registered User Member | Quote:
I've done quite a bit of template routing, both on the router table and free-hand and have never had this happen before. But then, this is the smallest piece I have ever tried to template route. I have tried with the grain running the length of the cleat and also with the grain running perpendicular to the length - problems with both. I could just drill out the corners and cut the straights with my jigsaw, but that would be too easy. There has to be a reason why this is happening and now it has become a challenge! JimC | |
| | #4 |
| Registered User Supreme Forum King | I've had that problem and solved it with a dual bearing bit. When you get to the chipped out part, turn it over and use the other bearing. You can hold the part in a clamp to keep your fingers attached to your hand.
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ |
| | #5 | |
| Registered User Forum Fanatic Join Date: Feb 2007 Location: Jerome, Idaho First Name: Larry Posts: 126 ![]() | Quote:
__________________ Larry "Have you hugged your pet today" Last edited by Fourleftpaws; 03-21-2008 at 09:59 AM. | |
| | #6 |
| Forum Contributer Supreme Forum King | Larry You may have hit the nail on the head, he said " then will catch and try to pull it from my fingers" It's always are to say with just one picture,,,but sometimes running the stock backs wards will stop the rip out but it must be done with care. ( very small cuts) =======
| | #7 |
| Registered User Forum Geek Join Date: Oct 2007 Location: Coconut Creek, Florida (near Ft. Lauderdale) First Name: Jim Posts: 262 ![]() | Jim, I'm in agreement with the other guys. I also feel doing small parts requires a lot of control as I've parts take off on me. Thus some kind of holding fixture really enhances the control and safety. I picked up one of these holders and it's proven to be worth it's weight in gold. Jim |
| | #8 |
| Forum Contributer Supreme Forum King | Hi Jim That's a neat jig.. ![]() Here's just one more way, I know it's low tech but works great because of the mass of the clamp and keeps it flat to the table top.. ![]() WOOD CLAMP http://www.harborfreight.com/cpi/cta...emnumber=92445 http://www.grizzly.com/products/7-1-...m-Action/H2844 =======
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-21-2008 at 12:11 PM. |
| | #9 |
| Registered User Forum Geek Join Date: Oct 2007 Location: Coconut Creek, Florida (near Ft. Lauderdale) First Name: Jim Posts: 262 ![]() | Hi Bob, I really like that Grizzly one. And it's inexpensive!! A hellofalot cheaper than fingers. Jim |
| | #10 |
| Registered User Supreme Forum King | Have you tried making "relief" cuts? This will help reduce any "chip-out". It's best to cut in the direction of the cutter. Unless you have a "small parts" holder, do as BJ stated. You can make your own or purchase one from either Rocklers or Woodcraft, or even as simple as the one BJ posted. ![]()
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| Master craft 10A plunge router with table problems | davistan | Table-mounted Routing | 2 | 01-01-2008 05:39 PM |
| Insert Plate size and 11.5" handle spread; how to prevent problems | Ladd | Table-mounted Routing | 34 | 12-14-2007 02:08 PM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| Problem mounting Dewalt Router to Caftsman Table Saw | apollo2000 | General Routing | 8 | 05-22-2007 07:42 PM |
