Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 03-28-2008, 12:00 AM   #1
DAUTTERGUY
Jr. Member
DAUTTERGUY is on a distinguished road
Cool Need some help
Gentlemen: Oh wizards of the Router Kingdom, I made a picture frame out of Cherry and Purpleheart. Took it to the Glazier today, He says "I need a Rabbet of at least 1/4 in instead I made one about 3/16ths". So am I safe to assume that I will place the frame between the fence and the Router Bit and do what is called a Climb Cut. Going Left to Right? This frame is already constructed otherwise I would I would be doing the normal Right to Left. PLEASE let me know before I I attempt something I might be sorry about. Thank You! :
DAUTTERGUY is offline   Top - Reply with Quote
Old 03-28-2008, 12:25 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi DAUTTERGUY
This is what I would do...
1. remove the fence.
2. chuck up a rabbit bit with the bearing on it...
3. set the height of the rabbit bit to what you want it to cut.
4. set the frame over the bit
5. turn the router speed down on the router to about 12,000 rpm #2 on most routers
6. turn the router on , put your rubber sole push block on the frame.
7. from the front side of the router table move the frame from left to right.← ← ← ←
8. when you get into the corners easy up with the pushing and just go around but keep the frame on the bit but always keep the part you are rabbitng in from of you.
9. once you have the rabibit in place take a sharp chisel and sq. out the corners..
10. do a bit of light sanding and you have it done for the Glazier
JUst a NOTE**** do go a bit deeper than 1/4" on the rabbit ,5/16" to 3/8" this will give the glazier a place to put in the holding points and some room for the glass and the backing board, and with some brown Kraft paper to cover the fastners you will have a nice frame..
Don't forget to put in key hole slot to hang it once it's glazed..
http://www.routerforums.com/68068-post37.html
http://www.routerforums.com/67388-post34.html
http://www.routerforums.com/jigs-fix...ake-one-4.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-28-2008, 02:18 AM   #3
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
That's a first class post Bj, I doubt that anyone will better it.
Harry
harrysin is offline   Top - Reply with Quote
Old 03-28-2008, 07:30 AM   #4
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
This could be the confusing part.
Move the frame from right to left with the bit inside and on the top edge of it.
AxlMyk is online now   Top - Reply with Quote
Old 03-28-2008, 07:39 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Mike
I agree, it's always hard to get that one over, But that's why I used the small arrows in the text and I made the small drawing to make sure he got the point
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-28-2008, 08:59 AM   #6
DAUTTERGUY
Jr. Member
Default Need help
Thank you Guys again!!! I poster my HELP CRY at 9:00PM here on the West Coast. and woke up to the answer. You Guys are wonderful, ME
Old 03-28-2008, 10:12 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi ME
You'er Welcome for my small part, how about a snapshot or two once you have it done... b/4 you have the glass in place would be nice
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-28-2008, 10:20 AM   #8
DAUTTERGUY
Jr. Member
Well I'll try. But, if I can not figure out how to Woute a Wabbet, how am I supposed to Download a picture?
Old 03-28-2008, 10:36 AM   #9
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi DAUTTERGUY
This should help
How Attachments Work/pictures
http://www.routerforums.com/howattachment.php
http://www.routerforums.com/help.php
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
