Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 04-08-2008, 09:09 AM   #1
andyk
New Member
andyk is on a distinguished road
Smile Freud FT3000 VCE Table Insert Issue
Hello All,
I have purchased a Freud FT3000 3 1/4 HP router and am in the process of building a table. I am to the point where I need to make a decision on the table insert. My problem is the largest insert that I can find is a 9x12 with a 1/4 inch support lip. The measurment at the width of the handles which do not seem to be removable is 11 7/8" which means that I would have to dismantle everything to do any maintenance, and bit changes would be a PITA.
Anybody have any suggestions to get around this? Even a commercially bought table would have this problem.
Thanks in advance for your suggestions.
andyk is offline   Top - Reply with Quote
Old 04-08-2008, 09:17 AM   #2
Charles M
Forum Fanatic
Charles M's Avatar
Charles M is on a distinguished road
Originally Posted by andyk
Hello All,
If you rotate the router on the insert plate so the handles are diagonal to the opening you should be able to remove it without interference.
Charles M
Freud America, Inc.
Charles M is offline   Top - Reply with Quote
Old 04-08-2008, 09:21 AM   #3
andyk
New Member
That is a possibility that I didn't think of. It is counter intuitive since the template mounting guide says to have the flat parallel to the front edge of the insert. Is this not a concern? Thanks for the quick response as I really need to move forward and get this done.
Old 04-08-2008, 09:52 AM   #4
kp91
Forum King
kp91's Avatar
First Name: Doug
Unless your plate is pre-drilled, you can mount it any way that works best. Also, depending on how your handles are mounted on your router, you can always just pop the plate up out of the table until it just clears the surface, then turn the plate and router together until you can lift it out.
Hope I'm describing it clearly
Oak park has some 11 inch plates.
http://us.oak-park.com/catalogue.html?list=BP-BP11-
1 John 1:9
Old 04-08-2008, 10:14 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi andyk
You may want to take a hard look at the links below, I have two Freuds and two of the CMT tables and the router is just right for the table..
11-3/4 x 14-3/4 insert plate
They are running a great deal on this table at 289.oo dollars note the list price...
http://www.amazon.com/CMT-999-500-02...7266973&sr=8-1
You can buy just the top for 234.oo dollars by why just buy the top when you can get the complete thing for 289.oo
http://www.amazon.com/CMT-999-501-09...7663664&sr=1-1
NOTE THE FREEEEEE Shipping
Just the insert plate for 80.oo bucks
http://www.amazon.com/CMT-999-501-11...7664229&sr=1-2
Hello All,
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 04-08-2008, 10:16 AM   #6
Charles M
Forum Fanatic
Charles M's Avatar
Rotating it on the insert is not an issue as long as the mounting or access holes do not interfere with anything like the hole for a starting pin, etc. Also, as Doug said you may be able to mount it parallel and just "fish" it out by rotating as you lift.
Charles M
Freud America, Inc.
Old 04-08-2008, 11:38 AM   #7
andyk
New Member
Bob,
While I will admit it looks impressive there are only 4 reviews, and yours was the only good review. I get the feeling that this table is somehow associated with Bench Dog and the products I have seen at the local WoodCraft store did not impress me. Can you eloborate any further?
Old 04-08-2008, 11:52 AM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi andyk
read the links below
http://www.routerforums.com/table-mo...-problems.html
http://www.routerforums.com/table-mo...e-cabinet.html
This table was sold by http://www.sommerfeldtools.com/
But he has a new model out now...that's why it's a great deal,,,
Most don't get it ,,, then fence can be use both ways but I use the ones I have with swing away...........that's to say you just swing the fence back and pop out the insert but most of the time it's not needed, with the BIG center hole you can change the bit out very quick and easy..
Bob,
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Table Mounting Freud 3000 woodman59 Table-mounted Routing 3 07-19-2008 02:23 AM
Freud 2200E and Bosch RA1171 Table 1973vw Table-mounted Routing 7 01-02-2008 05:45 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 02:08 PM
rousseau table insert trap Table-mounted Routing 6 07-06-2007 10:33 PM
Freud FT3000 collet? ezatt Starting Off 4 01-19-2007 04:54 PM
