| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Jr. Member | I ordered a router table from RT-1000 woodworking and they agreed to drill teh plate to fit my Bosch 1617 router base. They are having some confusion as to where to actually drill the holes. Does anyone know of a screw hole template to use to drill the holes for mounting the base to the plate that can be emailed? I really don't want to send my base all the way to Canada! |
| | #2 |
| Marine Engineer Forum King | You could always xerox/scan your baseplate- I've used that technique to mount light fixtures, etc. Just make sure the scale is 1:1. Just a thought.....
| | #3 |
| Registered User Jr. Member | Excellent Idea I'll give it a try Thanks |
| | #4 |
| Registered User Sr. Member | Hi BigRoccek: An extension to Doug's excellent idea is to place a six-inch rule next to the base plate while scanning it. That way, there is a scale reference, just in case the copy/scan isn't 1:1. There is one other issue with the Bosch base plate. I have the Bosch 1617EVSPK set-up (plunge and fixed bases.) On each base plate there are two sets of holes for mounting the base plate to the base. It would be a good idea to mark the copy/scan to indicate which three holes (plunge base) or four holes (fixed base) to use for the RT-1000 plate. Cassandra |
| | #5 |
| Forum Contributer Supreme Forum King | Just to add to Doug's post ![]() The PDF file below is the manual for the Bosch. You can download it for a free and have diag.copy then use it ..if you used Adobe 7.0 you can select any part of the PDF and have a picture to send to RT-1000 via.email and they will have a pattern they can use it to drill the plate for you.. you just need to insert the numbers.. http://www.plumbersurplus.com/pdf/09575.pdf =================
| template guides for Bosch Colt | RuggerJoe | Guide Bushings and Templates | 8 | 07-24-2008 12:17 AM |
| Screw sizes for the plunge base on Bosch 1617 | deck99 | Table-mounted Routing | 4 | 04-16-2008 10:48 AM |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Bosch 1617 router base problem | bill kay | General Routing | 4 | 01-09-2008 12:53 PM |
| Which hole pattern should I get (plate for a Bosch 1617)? | Nickbee | Table-mounted Routing | 1 | 11-23-2007 07:49 PM |
