| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Sr. Member | Anyone know what size screws the plunge base takes on the Bosch 1617evspk? Thanks, deck |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Deck The norm is M4 x 16mm but your best to get replcement ones that are a bit longer M4 x 20mm Allen flat head from Ace Hardware.. Bosch maunal below http://www.plumbersurplus.com/pdf/09575.pdf ========
| | #3 |
| Registered User Sr. Member | Bob, What's the M4, the length? 16mm is the screw size? |
| | #4 | |
| Forum Contributer Supreme Forum King | Hi Deck M4 is the diam. and the thread size (in metric), the 16mm is the over all length from the top of the head to the bottom of the screw...(on a flat counter sunk type metric screw ) ============== But in the states it would be called out like 8-32 x 5/8" in SAE sizes. 8 is the diam.32 is the threads per. in. and the 5/8" is the over all length. http://www.boltdepot.com/fastener-in.../Notation.aspx ========= Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 04-16-2008 at 12:32 AM. | |
| | #5 |
| Registered User Sr. Member | Thanks bob. Deck |
| Plunge base for Bosch 1606 | carlseibert | General Routing | 11 | 07-04-2008 12:21 AM |
| Bosch 1617 screw hole template | bigroccrek | Table-mounted Routing | 4 | 04-11-2008 10:37 AM |
| Colt plunge base | bobj3 | Jigs and Fixtures | 19 | 04-01-2008 08:54 PM |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Bosch 1617 router base problem | bill kay | General Routing | 4 | 01-09-2008 12:53 PM |
