| This is a discussion on Screws to hold my T-tracks? within the Table-mounted Routing forums, part of the Routers category; I am just wrapping up my router table top. It turned out SWEET! I'll post ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I am just wrapping up my router table top. It turned out SWEET! I'll post some pics soon. I cut the dadoes for the two t-tracks that secure my fence and a dado across the table for my long feather board t-track. My top is MDF. What are the best screws to secure the tracks? Does anyone ever use screws and epoxy? Thanks, deck Last edited by deck99; 04-19-2008 at 10:54 PM. | ||
| | #2 (permalink) | ||
| Retired Moderator ![]() |
Flat head wood screws with either a Phillips or square drive will do the trick. No glue should be needed.
__________________ Mike Please edit your profile with a name and location so we can better assist you. | ||
| | #3 (permalink) | |||
| Forum Contributor ![]() |
Hi deck99 I would suggest Allen Flat head screws ( not phil.hd/slotted hd..they like to cam out and leave a sharp edge ) and nuts and flat washer... You want the track to stay true for a long time and screws will work lose in time then you have a striped hole you can't do much with... MDF just can't hold screws very well without striping out..and epoxy is a no no you may need to replace the track one day...if it gets damaged...little nicks can make it some junk Alum. rail...on the router table... ========= Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. | |||
| | #4 (permalink) | ||
I used #6 phillips flat head sheet metal screws. #8 heads are too big and stick up over the bottom of the rails. Wood screws will pull out of MDF. You don't actually need to get the screws real tight. All you're doing is holding something steady.
__________________ . Never, under any circumstances, combine a sleeping pill and a laxative on the same night. Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | ||
| Miter tracks and Tee tracks | Gerry Kiernan | Table-mounted Routing | 18 | 02-05-2008 10:37 AM |
| Hold the mice | cbsjoez1935 | Table-mounted Routing | 14 | 05-03-2007 12:24 AM |
| An alternative way to hold stock | harrysin | Guide Bushings and Templates | 5 | 02-18-2007 02:47 PM |
| craftsman router table screws | reds_21 | Table-mounted Routing | 6 | 08-18-2005 02:57 PM |
| Phillips and Brass screws (tips) | CanuckBeaver | Tools and Woodworking | 15 | 01-12-2005 04:17 PM |
