Rate This Thread - Bit Speed on Plexiglass????.
Thread Tools Display Modes
Old 06-16-2008, 11:27 PM   #21
F3RR3T
Jr. Member
F3RR3T is on a distinguished road
i find it helps when making your cut to go slow, because the plastic really sucks up the heat and can warp if your not on a flat surface
F3RR3T is offline   Top - Reply with Quote
Old 06-21-2008, 11:34 AM   #22
Tale Gunner
Jr. Member
Tale Gunner's Avatar
Tale Gunner is on a distinguished road
According to all I have done with Plexiglass or Acrylic glass it has to be cut with very low speeds allowing time to cool after each cut.
Tale Gunner is offline   Top - Reply with Quote
Old 06-26-2008, 07:02 PM   #23
mftha
Forum Fanatic
mftha's Avatar
mftha is on a distinguished road
I know this response does not answer the question, but I am very interested in the answer for both lexan (polycarbonate) which has very good mechanical strength but does not have good chemical resistance against organic solvents, and acrylic (plexiglass), which has good chemical resistance.
Do the O-flute router bits live up to their advertising as the best for cutting lexan and acrylics?
Tom (NOT Template Tom; I'm nowhere near his league)
One does not know what they are doing until they can make a mistake and correct it.
DO Something, DO ANYTHING to Stop Global Warming
mftha is offline   Top - Reply with Quote
Old 06-28-2008, 01:18 PM   #24
mftha
Forum Fanatic
mftha's Avatar
I have been checking out various web sites for router bits for cutting polycarbonate and acrylic. The most informative seems to be Onsrud. They sell a variety of bits but they all recommend high speeds for cutting. As my budget allows, I will be exploring and reporting. Today I am going to try two O-flute bits from Amana on lexan from Lee Valley. The Delvie's Plastic web site does indeed have very good prices for acrylic sheets.
Variable Speed vs. Fixed Speed Phillip K General Routing 24 07-12-2008 10:29 PM
How do you tell a router's speed??? allthunbs Table-mounted Routing 11 07-07-2008 03:08 PM
rule of thumb for variable speed? rprice54 General Routing 3 01-11-2006 05:50 PM
Router speed controls RustyW Starting Off 1 12-29-2005 06:42 AM
variable speed routing Dean VV Table-mounted Routing 3 03-23-2005 10:12 AM
