Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 04-23-2008, 10:02 PM   #1
garycurtis
Sr. Member
garycurtis is on a distinguished road
Default Bit Speed on Plexiglass????
I'm planning to make a few jigs using plexiglass. The bit can be any modest straight bit. My first few attempts ended with the plastic shattering. Even with relatively shallow cuts.
What am I doing wrong?
Gary Curtis
Northern California
garycurtis is offline   Top - Reply with Quote
Old 04-23-2008, 11:37 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Gary
It maybe the bit you are trying to use, most straight bits are Not made to plunge in... they have a blank spot right in the center of the bit .
Try one like below
http://www.mlcswoodworking.com/shops.../bt_plung.html
Or
http://www.mlcswoodworking.com/shops.../bt_solid.html
Note.. the picture below, this is the one you should use in a router (upcut) down cut in a plunge router..
Gary Curtis
Northern California
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 04-24-2008, 02:59 AM   #3
fibertech
Forum Geek
fibertech's Avatar
fibertech is on a distinguished road
Send a message via AIM to fibertech
Bob, Where can you get Plexiglass? I am hoping to make a couple of router bases and want clear. Thanks in advance. -Derek
fibertech is offline   Top - Reply with Quote
Old 04-24-2008, 10:30 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Derek
I'm not a big fan of Plexiglass ,it's great if you need to replace some glass but for jigs I don't like it ,, it's almost always under size and it is almost always comes with clear or blue film on it that's are to draw on...and like the name it will flex easy..HD/Lowes/Ace has it on hand.
But I do like acrylic ,it almost always comes with a paper cover that I can draw on and it comes in a true size, if you ask for 1/4" it will be 1/4" thick unlike Plexiglass ,if you ask for 1/4" you will get 9/32" thick the norm...
I sometimes get the acrylic from HD or Ace but you must look hard for it..
and take a your ruler with you...
When I have the time I also get some from the plastic companys in town out of the cut off box,,they just about all have one...some great deals, 50 to 75 cents ea....the stuff I like best is the scratch resistance to a point ,it's a flim that they put on the plastic,I think .......
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 04-25-2008, 12:39 AM   #5
RustyW
Forum Geek
RustyW's Avatar
First Name: Rusty
RustyW is on a distinguished road
Plexiglas is acrylic. It's just one of many brand names for an acrylic sheet product. The reason the stuff at home centers is undersized and with plastic rather than paper masked, is because they get the cheapest available product. I prefer polycarbonate (Lexan,Hyzoid are common brands) which can be worked like wood with common woodworking tools. Acrylic I treat more like mdf, if you drill it eventually it will crack out from the hole. Luckily for me, I work at a glass shop near lots of gravel plants. At least once a week I cut and install scratch resistant polycarbonate windshields in their equipment. So I have tons of cut offs and scraps.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline   Top - Reply with Quote
Old 04-25-2008, 02:49 AM   #6
fibertech
Forum Geek
fibertech's Avatar
Thanks guys. I have a couple of Tap Plastics in the Seattle area that I can check. We are currently trying to sell our house and move further north. That would put me 25 miles from the Grizzly headquarters. My shop will be more than twice what it is now. I want to devote much more time to this hobby. -Derek
Old 04-25-2008, 08:12 AM   #7
kp91
Forum King
kp91's Avatar
First Name: Doug
Rusty,
If you're having trouble drilling plexi, you can try a trick that works about 85% of the time for me. Deliberately dull the drill at the point where the grind angle transitions to the outside diameter of the bit. By dulling these 'ears', it will prevent the bit from catching as you drill.
You can also pilot drill your holes with a propane torch and a nail.
1 John 1:9
Old 04-25-2008, 11:49 AM   #8
Lee Brubaker
Forum Fanatic
Lee Brubaker is on a distinguished road
For jigs I prefer polycarbonate. It wont shatter & stands up to hard use. As BJ says, take your ruler with you because often in plastics the thickness's are in mm's instead of inches.
Lee
Lee Brubaker is offline   Top - Reply with Quote
Old 04-25-2008, 02:01 PM   #9
cbsjoez1935
Forum Fanatic
cbsjoez1935 is on a distinguished road
Gary
I noticed that you did not respond to the suggestions on bit speed for plexiglass. I am not sure what problem you are having. If it is using the bit as a drill bit, you are going to need the plunge cut type, as suggested by BobJ. If you are attempting to use a staraight cutting bit as a "planing bit" on the edges that is something else. Could you please clarify your usage? Too high a speed with too low a feed speed could cause melting.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline   Top - Reply with Quote
Old 04-25-2008, 03:30 PM   #10
garycurtis
Sr. Member
I am the OP on this thread. I'll be making jigs, so there will be a few holes bored straight in, but the breakage has been primarily on cutting and shaping edges.
I got all of my Plexiglass and Polycarbonate (known as Lexan) from Hastings Plastic in Santa Monica, Calif. Behind their store, they have several dumpsters. A treasure trove.
Again my question. What speeds do I use for drilling (I have end mills) and for edge shaping?
Gary Curtis
Variable Speed vs. Fixed Speed Phillip K General Routing 24 07-12-2008 11:29 PM
How do you tell a router's speed??? allthunbs Table-mounted Routing 11 07-07-2008 04:08 PM
rule of thumb for variable speed? rprice54 General Routing 3 01-11-2006 06:50 PM
Router speed controls RustyW Starting Off 1 12-29-2005 07:42 AM
variable speed routing Dean VV Table-mounted Routing 3 03-23-2005 11:12 AM
