Rate This Thread - Which bit for router "jointing"?.
Thread Tools Display Modes
Old 04-24-2008, 06:31 PM   #1
Birch
Sr. Member
Birch is on a distinguished road
Default Which bit for router "jointing"?
I seem to be having a short brain circuit here fellas' I want to put a nice edge on some boards before putting them together with pocket screws/glue. Should I use a nice 1/2" solid carbon spiral bit in my table? Or a trim bit with bearing? Seems I used to know this and now I can't remember what I did before?
Does this happen a lot when you pass 65? Or was it 66?
Birch is offline   Top - Reply with Quote
Old 04-24-2008, 06:48 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Birch
Just ny 2 cents
I like to use the 1/2" solid carbon spiral bit because of the skew angle on the bit..
it will cut unlike the standard chop angle on the trim bit..
bobj3 is online now   Top - Reply with Quote
Old 04-24-2008, 08:51 PM   #3
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
I use the one that Bob and Rick sell.. it's a 1/2 inch flush trim bit and but it also has a shear angle on it.
http://us.oak-park.com/catalogue.htm...product=42-116
The one Bob mentions may work as well or even do better than this but I tried this one out with the jointer fence and it worked well.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 04-25-2008, 01:28 PM   #4
Birch
Sr. Member
See....I TOLD ya I knew it. Just couldn't remember. I use the 1/2" shank 1/2" downcut carbide spiral bit. Which makes it an UPcut in my table. Thanks for the memory jog fella's.
Old 04-26-2008, 11:05 AM   #5
Senior Moderator
Supreme Forum King
Mike has disabled reputation
The method of use does not change the type of bit cut. An up-cut pulls the debris towards the router and a down-cut pushes it away from the router. Any tear out that will occur will be on the side the debris is pushed towards, in your case the table mounted down-cut will cause tear out (if any) on the top edge of your material.
