| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Forum Geek | I just watched "the Router Workshop" yesterday and realized that Bob and Rick pop their router out of the table often. I have the Oak-Park table top and insert that they use and mine fits very tightly. What's the best way to make it fit looser? Shave off the plastic insert (base plate) with something, or shave off the table top 'hole' with something? ~Julie~ |
| | #2 |
| Marine Engineer Forum King | Julie, I actually like the fact that the plate fits into the table slightly. I have had the oak park table for about four years now, and it has loosened up some, but is still nice and snug. I think this gives more accuracy. My previous table with an insert was one I had made, and I had oversized the cut just a tad too much and it was awful. I ended up using body filler to tighten the hole up some. When I had my router table in the extension wing of my table saw, it was bolted up tightly, but a pain to change bits. The tight insert in the oak park table is a happy medium in my humble opinion. If you find you just have to loosen things up a bit, I would recommend lightly sanding one side of your insert plate and see what happens.
| | #3 |
| Senior Moderator Supreme Forum King | Gosh Julie, you women are never satisfied. Now if I may be so bold... do you really want to have a sloppy fit? I realize it may be a bit more of a challenge when it fits so snuggly. The plus side to this is it wont shift when you are making a cut. Other companies use screws to secure their plates, or special "corner snugging" clamps like on the Rousseau plate. All that trouble to make sure their plates have a tight fit. I guess a simple rule of wear is true: The more you use it the looser it fits... ![]()
| | #4 |
| Registered User Forum Geek | Well, I can't pop mine out to change bits. Have to bend down and do it under the table. On the show they pull it up and out and lay it on the table. (Oh dear, I just re read that and better stop before I get in trouble!) ~Julie~ |
| | #5 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| Best bit for tight fitting box joints? | Nickbee | Router Bits - Types and Usage | 9 | 12-31-2007 01:13 AM |
| Insert Plate size and 11.5" handle spread; how to prevent problems | Ladd | Table-mounted Routing | 34 | 12-14-2007 02:08 PM |
| rousseau table insert | trap | Table-mounted Routing | 6 | 07-06-2007 10:33 PM |
| Router Insert Cut Out too Big | t2true | Table-mounted Routing | 10 | 02-24-2007 01:41 AM |
| Router Table Insert | dtoney5817 | Tools and Woodworking | 4 | 11-25-2004 08:58 PM |
