| Table-mounted Routing Discuss Incra Intellifence in the Routers forums; My garage sale router table came with an Intellifence. I can't find a manual on the Incra website and ... |
| New Reply | Quick Reply |
| | Thread Tools | Search this Thread | Display Modes |
| | #1 | ||
| Registered User Sr. Member |
My garage sale router table came with an Intellifence. I can't find a manual on the Incra website and was wondering if anyone has a link to a pdf of the intellifence manual they could give me? Thanks, rstermer | ||
| | #2 | |||
| Forum Contributer Supreme Forum King |
Hi rstermer This one should do the trick Intellifence incra Intellifence The new Incra WonderFENCE is Incra’s second-generation general-purpose router table fence. Like the IntelliFENCE http://www.woodpeck.com/media/WF_Manual.pdf http://www.woodpeck.com/wonderfence.html ========== Quote:
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/...op_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html | |||
| | #3 | |||
Bob- Thanks! I don't really like the fence and I'm thinking about replacing it because it doesn't have any t- tracks or other means of mounting featherboards and it has to be backed up to prevent it from moving on me in use due to anemic clamps. Any ideas as to the best fence? rstermer | |||
| | #4 | ||
Hi rstermer Well they make some good ones but they are not cheap but I always say if you want the best make your own. I order some last week, see below,, but he has all types at the right price.. http://cgi.ebay.com/ws/eBayISAPI.dl...em=330233029881 Just a note**** You can buy the tee nuts that just slip in just right but they are about .40 cents each and a Sq. nut will do the the same job at .03 cents ea. plus a carr. bolt for the stud type fastners at .04 cents ea. It's the same stuff they use for many jigs.. like the one below, the ones below are 2" tall that has been stacked up to 4" tall with 2 ea.,parts with a 1/4" pin down the center to keep it true... ===========
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/...op_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Last edited by bobj3 : 05-12-2008 at 05:39 PM. | ||
| | #5 | |||
Thanks for the link. Very nice fixture you made. Does it come pre-drilled for the 0.25 pin or did you do that yourself? rstermer Last edited by rstermer : 05-12-2008 at 07:13 PM. | |||
| | #6 | ||
Hi rstermer Thanks,, nope it's not predrilled but it's not a big deal just clamp them up as a pair and drill the hole for the 3" long pin ... on the drill press...tap the pin in the hole and it's done. ============
| | #7 | ||
| Registered User New Member |
Hi rstermer I have a PDF of the Inellifence Manual. If you would like to PM me your email, I will send it to you. Bye for now | ||
| Incra track/Featherboard tip | LonePalm | Tools and Woodworking | 2 | 03-14-2008 07:30 PM |
| Incra question. Forum shopping | S Bolton | Jigs and Fixtures | 1 | 11-03-2007 09:11 PM |
| Incra Ultra Lite Jig | S Bolton | Jigs and Fixtures | 7 | 10-21-2007 02:56 AM |
| Incra Clamp | S Bolton | Jigs and Fixtures | 11 | 09-20-2007 09:43 AM |
| Incra 1000SE | boxer | Tool Reviews | 2 | 04-20-2006 08:10 PM |
All times are GMT -5. The time now is 06:49 AM. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 |
