Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 05-16-2008, 03:01 PM   #1
cbsjoez1935
Forum Fanatic
cbsjoez1935 is on a distinguished road
Default Homebrew Happenings
Well I finally got around to building my version of the RWS table, using their table top. I had not received my stimulus check, as yet, so baltic birch or cabinet grade stuff was out and I had to build it with what scraps I had. I used 1/2" ply and instead of 1 X 2 supports, I used left over deck ballistae (2 X 2) I struggled through the dados, for the bit holder tray, stupidly going the wrong way on my other makeshift table (3/8" ply on workmate) climbing instead of cutting in the bit direction and wondering why the piece kept trying to move away from the fence. I did not build the base cabinet, as yet, but secured the frame to a 3/8" ply sheet, screwed a 2 X 4 onto the ply and used that to support the whole thing on my B & D Workmate. That may seem strange, but after lowering the Workmate's feet to their bottom position, the height works for me. With my wonderful behemoth ready, I decided to make the RWS miter gauge with some poly cutting board. I framed the slot out with sticks, using my 1" brass guide as a measure and cut 5/8" holes to remove excess waste. With a 1/2" shear angle flush trim bit mounted, I produced enough poly confetti for a New Year's Party. It stuck to everything. Who cares? I was going to have my miter gauge. Boy, was I wrong. First off, do not use double sided tape to hold the sticks on poly. They did not hold up under the pressure and my slot got wavy and ultimately useless. Next time I will pre-cut the end slot holes with a 1" Forstner bit, cut the excess out, as before. Using the 1/2" bit, line up the first cut with my fence, reverse the poly and cut the second pass after adjusting the fence. Maybe this time it will work, but hey the fun is in trying. Sorry for the long post, but I hope it gave some information.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline   Top - Reply with Quote
Old 05-17-2008, 01:04 AM   #2
Glenmore
Forum Moderator
Supreme Forum King
Glenmore's Avatar
Glenmore will become famous soon enough
Send a message via Skype™ to Glenmore
Joe sounds like I was working on it instead of you. Never a wasted moment. Sounds like you were having some fun. But hey you learn by the mistakes I know I do. It is like a pilot if you walked away from a crash it was a fine landing.
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline   Top - Reply with Quote
Old 05-19-2008, 01:10 PM   #3
cbsjoez1935
Forum Fanatic
Hi Glenmore,
Thanks for the sympathetic words. I have decided to not use a poly cutting board to make the miter gauge out of (just too messy with all those shavings flying around). I will venture to use Phenolic or experiment with tempered hardboard. Should be fun and a good learning experience again. Do you happen to know why there is a semi-circle opening on the top of the one Bob & Rick use, where the locking knob is located? I would think a simple swivel point would suffice.
Joe Z.
Old 05-19-2008, 02:57 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hey Joe
Are you talking about the one below ?
http://us.oak-park.com/catalogue.html?list=RTS-MGS-
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-19-2008, 05:47 PM   #5
cbsjoez1935
Forum Fanatic
Hi Bob,
Yep, that's the one. I am thinking that there is a swivel point just below that semi-circle cut out and the locking knob sits in that cut out to lock down the angle. I don't think I am going to need those other accessories and only intend to use it when cutting slots at an angle, ala the RWS shop stool, so I am not ordering the miter gauge set (too steep for me).
Joe Z.
Old 05-19-2008, 06:31 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
I have two ,one I made and one I got from RWS, they both work great.
The swivel point is just in front of the knob right on the edge, the semi-circle is needed if you want to use the jig for angels ,if not you don't need to put it in but it's a easy job with a circle jig and plunge router.
homebrew-happenings-0182.jpg  homebrew-happenings-0183.jpg  homebrew-happenings-0184.jpg  homebrew-happenings-0185.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-20-2008, 10:50 AM   #7
cbsjoez1935
Forum Fanatic
Bob,
Thanks for your pics and comments. I think I finally understand why the semi-circle cut out was put there. I don't know if I am on a "fools errand" trying to exactly duplicate the RWS version, so I am going to put a few pennies away for awhile and purchase one. With that to work with, I may just venture into building another, just to see if I can do it. Then I would need to know where I can purchase those nice thick blocks of UHMV that RWS uses for their fences and jigs.
Joe Z.
Old 05-20-2008, 11:19 AM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
The UHMW can be nasty to route, it leaves strings unlike wood and can jam/break a bit in a heart beat..
UHMW stock
http://www.ptreeusa.com/uhmw_list.htm
http://www.ptreeusa.com/uhmwproducts.htm#strips
The thick ones I get from MLCS, 1 1/2" thick
http://www.mlcswoodworking.com/shops..._safety_anchor
Replacement Backer Block
#9496............................................. .................SALE $11.95
Thick UHMW stock
off eBay sometimes..
The RWS jig would be easy to copy, it's the pin holes that hard to get right,,
It's setup for 1/2" and 3/4" stock only, that's why I made one that will do 1/4" stock to 1 1/2" wide stock...
If you want a snapshot of the holes let me know and I will post one..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-20-2008, 04:39 PM   #9
cbsjoez1935
Forum Fanatic
Bob,
I am not jumping into the making of the miter gauge again, just yet, but when I asked about the UHMV stock, I was looking for the place where I could get the 16"-19" length, 1-1/4" to 1-1/2" thick and 2' to 3"wide to use for fences and blocks. The sites you were nice enough to send did not have those. I wish MLCS did have them for I do a lot of business with them. Oh well, thanks anyhow for your help which is always appreciated.
Joe Z.
Old 05-20-2008, 06:41 PM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
OK, don't put off what you can do today or you may never get it done
Here's one hahahahahahaha, just cut off what you need hahahahahaha then save the is rest for other projects ...
http://cgi.ebay.com/UHMW-Polyethylen...QQcmdZViewItem
http://cgi.ebay.com/NEW-Lifetime-37-...QQcmdZViewItem
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
