Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 05-23-2008, 10:36 AM   #1
Jtomwoods
Jr. Member
Jtomwoods is on a distinguished road
Question Jointing long boards
I am trying to get a straight edge on some long boards (8 footers) using the jointer fence. Using short boards, I have adjusted the fence to eliminate snipe. When I joint the longer boards, it seems I get a curve in the board. I can edge joint two boards and place one on top of the other matching up the jointed edges, but they don't line up. I would appreciate any help on this. I am assuming this is technique oriented.
Thanks - Tom
Jtomwoods is offline   Top - Reply with Quote
Old 05-23-2008, 10:50 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Tom
Jointing long boards on the router table is always trickey,,, I would suggest you use two or more feather boards on the out feed side of the router table fence, the trick is to keep the stock to the fence all the way down the pass...
You can make your own feather boards quick and easy if you don't have some on hand.
http://www.routerworkshop.com/featherbd.html
http://www.routerworkshop.com/jointer101102.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-23-2008, 03:55 PM   #3
AlanWS
Jr. Member
AlanWS is on a distinguished road
For long boards, I would find a long reference edge, and use that as a guide with a hand-held router for edge jointing. A step fence is more convenient for shorter boards, but with long boards the need to a very long straight fence makes it impractical, particularly in a small shop. It takes twice as much room to move the board as it does to move the router.
AlanWS is offline   Top - Reply with Quote
Old 05-23-2008, 04:37 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Tom
Here's just one more way to get the job done..if you want to use your hand held router.
Clamp the 2 boards down to the work bench with some plywood under them leave a grap in the boards you are going to use then clamp two boards on top of the boards you want to joint, run the router bit down the center of the slot between the boards using the top boards as a guide,,, you can use a 1/4" to 1/2" bit to do the job, the boards will match up right on the button because you are plowing two boards at one time.
Besure to mark your boards b/4 you start the job...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-24-2008, 09:39 PM   #5
Jtomwoods
Jr. Member
Thanks guys for the ideas. They are probably more practical than trying to do this type of work on the table.
Old 05-25-2008, 09:11 AM   #6
Electron
Sr. Member
Electron is on a distinguished road
bobj3, I've never tried this method but, because the cutter is rotating in the wrong direction for one of the boards, I wonder how smoothly the router will move and what the cut will look like on this side, just a thought.
Electron is offline   Top - Reply with Quote
Old 05-25-2008, 12:22 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Electron
You should give this a try out,,,,I got the ideal from Bob R. from one of his shows, he was doing panel job and wanted the panels to fit just right and tight, and I said it works great on panels out how with two boards that you want to fit tight and it worked out just great because it's a mirror cut.
The gap between the boards takes the stress off the bit and the router.
It's only taking off a 1/16" to 1/8" if that so no need to worry about traping the bit in the boards...or running in on a climp cut...if you use a sheer type bit it will come out very clean just like doing in on a jointer...and it's a mirror image cut...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-25-2008, 03:00 PM   #8
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
RWS (Oak Park) episode #6 shows exactly how Bob R. does this. It's really the best way of "jointing" your long boards together.
Ken
"A VETERAN"
Old 05-25-2008, 10:05 PM   #9
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
http://www.woodworkingchannel.com/do...eo_library.php
"Construction tricks of the trade" is the video you want to watch.
AxlMyk is offline   Top - Reply with Quote
Cutting boards for gifts.... gad5264 Project Plans and How To 13 10-19-2007 12:13 PM
buying S4S boards peacefrog Tools and Woodworking 6 10-14-2007 09:53 AM
sliding dovetails on long boards Neanderthal Portable Routing 5 09-21-2007 09:42 AM
Planing with a Router Gilbear Portable Routing 48 06-05-2007 04:45 AM
Router Jointing Drick General Routing 1 12-19-2005 10:21 PM
