Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 06-20-2008, 08:57 AM   #1
DAUTTERGUY
Jr. Member
DAUTTERGUY is on a distinguished road
Default Another Question
Seems as tough I am full of questions,but this is the place for the answers. I am in the process of making Two under the bed Blanket Boxes, for a wedding gift. I made one but the Dove Tails are quite Tight. I am using the Keller Jigs. Does the Old Addage hold true in Table Mounted Routing "Highten To Tighten-Lower to Loosen"? The Pins fit but had to use the "O'le Fine Adjusting Tool" I would like them to fit snug,but without any beating. Thanks
DAUTTERGUY is offline   Top - Reply with Quote
Old 06-20-2008, 09:05 AM   #2
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
"Heighten To Tighten-Lower to Loosen"
That sure does hold true.
Harry
harrysin is offline   Top - Reply with Quote
Old 06-20-2008, 09:43 AM   #3
DAUTTERGUY
Jr. Member
Thank You Harry, All my "STUFF" is in a Two Car Garage. Maybe some day I'll have a shop as nice as yours"Three Minute Egg"
Old 06-20-2008, 09:49 AM   #4
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
You're doing well, many members only have part time use of a single garage.
Harry
Old 06-20-2008, 10:22 AM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
Not always true
Because the Keller jig is a through type dovetail jig it must set dead on..most use a 7/16" 7deg.router bit..
I would suggest checking your setting on the bit...the bit must be right at the top of the wood, not below, not above, right flat with the stock..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-20-2008, 10:34 AM   #6
DAUTTERGUY
Jr. Member
Bob, are you saying that the height of the bit must be the exact height of the piece to be cut? I laid a piece of the matching wood on the template and scribed a line. Keller says "Leave a 1/16 above the scribed line,or a 1/32nd above and then sand off the overage" I tried this and the fit is VERY TIGHT.
Old 06-20-2008, 01:32 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi DAUTTERGUY
This is one time you don't want to do what they say..
Take a piece of the same stock you are going to put the dovetails in (a cut off piece ) set it on the jig template move the bit up or down until the bit is the same as the cut piece....the pencil line can be off just a bit and most of the time it is...
The dovetails will come out right on the button without the need to sand or to use a trim bit to get them flush....and they will fit just right...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-21-2008, 09:12 AM   #8
DAUTTERGUY
Jr. Member
Thanks one more time Bob, You Saved my Bacon,and a lot of Pounding!!!.
Old 06-21-2008, 10:07 AM   #9
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Not being familiar this particular jig, I can't make much sense out of your description Bj. how about a couple of shots that will reveal all.
Harry
Old 06-21-2008, 10:21 AM   #10
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
This is how you adjust it for T or L fit.
http://www.eaglelakewoodworking.com/...oogle_high.htm
router è ancora il mio nome
Router is still my name is offline   Top - Reply with Quote
new omnijig user with a question dracjm Introductions 1 06-29-2008 03:09 PM
DC Question angus Lobby 3 03-31-2008 08:29 PM
Where do I post this type of question? RouterFool Introductions 1 03-30-2006 09:54 PM
craftman router question tsbrewers Table-mounted Routing 7 05-16-2005 06:54 PM
Question: Sub Base Plate and guide bushings trap General Routing 3 04-17-2005 08:25 PM
