| Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router. |
| | #1 |
| Registered User Sr. Member | I used my router table to to build 8 adirondack chairs this weekend. I routered quite a bit of wood with the Hitachi. The switch must have filled up with fine saw dust and essentially remains in the on position. Anyone ever have this issue? I haven't dissasembled yet to clean it. I need to add a switch to my table so I don't need to use the router switch so much. deck |
| | #2 |
| Registered User Forum Fanatic | Hi Deck, I have a MV12 also, but have never run into that problem. After each job I do with it, I take off the base plate and go at the bottom section with my shop vac. I then go over the whole thing with an airblast from my compressor. If fine sawdust has bound up your switch, this system may just help free it up. Its worth a try. Joe Z.
__________________ JoeZ If you never made a mistake, you never tried anything
| | #3 |
| Forum Contributer Supreme Forum King | Hi Deck Most router are not made to run upside down to long... to many pockets for the saw dust to fall into..=======
| | #4 |
| Registered User Forum King | Hitachi M12v has 5 year wrty. call the support and they will send you a new switch or if you take it to service center will fix it for you for free.
__________________ router è ancora il mio nome |
| | #5 |
| Registered User Jr. Member | If you're going to clear out the dust, debris yourself then you may want to use a brush and not compressed air. Compressed air can force the debris into areas you don't want. The federal government has done studies that show the use of compressed air to clean machinery reduces the lifetime of the machinery. |
| | #6 | |
| Forum Contributer Supreme Forum King | Hi WoodTroll hahahahahahahahahaha that's the Fed. job I want to get... hahahahaha ![]() Only the US federal government would pay someone to check that out... ![]() hahahahahaha LOL ,any one want to buy a US federal government toilet seat, for only 880.oo dollars ,,,pls.order by ms or ans part number... only in White ,back or other colors have been discontinue...========= Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 07-02-2008 at 03:39 PM. | |
| | #7 |
| Registered User Jr. Member | Hi! I believe they studied those effects back around the sixties. I've never searched for that type of information but it may be freely available. It would be interesting to see all the things(myths, etc) the goverment has researched, tested, and concluded. As well as all the receipts for government purchases! |
| Bosch 1617 switch repair | reikimaster | General Routing | 12 | 11-27-2007 10:15 AM |
| Setting the proper RPM on the Hitachi M12V | jrs4464 | General Routing | 5 | 01-10-2007 10:34 PM |
| AC switch ahead of plug on Hitachi slowstart router? | Joe Lyddon | Starting Off | 6 | 09-05-2006 04:34 PM |
| M12V pricing/seller | dtaylor15 | General Routing | 1 | 01-28-2006 12:41 AM |
