Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 07-10-2008, 06:00 PM   #1
mikehop
New Member
mikehop is on a distinguished road
Default Solid Core door
I have a solid core door bench and was wondering if I could insert a router into it and make it a router table/workbench. Is this a good idea? If so are there any suggestions for making it more router table friendly, such as laminating the top or adding additional support?
Thanks,
mikehop is offline   Top - Reply with Quote
Old 07-10-2008, 11:05 PM   #2
LeeC
Jr. Member
LeeC is on a distinguished road
Hi Mike
I have a workbench made fro a solid core birch door. It is 11/4 inch thick. You would have to rout out about 7/8 inch out of the door in order to get any adjustment with the router. If the router was permanently mounted, it would be almost impossible to change bits. In order to use an insert plate, you would have to relieve the surface by the thickness of the insert. This leaves only particle board to support the router. It would not last very long and your router would come out to see you. Leec
LeeC is offline   Top - Reply with Quote
Old 07-10-2008, 11:30 PM   #3
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
I too have a bench made from a solid core door which has withstood close to 30 years of hard work, had I laminated it I'm sure that it would be on it's fourth covering by now, so in short, I would not laminate. As for fitting a router, it depends on a number of things including: it can't be easily moved around the shop and will there be enough clearance when a long length is being routed, also if a big job is being worked-on it's inconvenient if some part requires use of the table mounted router, in short, my recommendation is a separate table.
Harry
harrysin is offline   Top - Reply with Quote
Old 07-11-2008, 12:35 AM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Mike, mounting a router in the end of a large work table can be done but unless it is set up for a specific job your adjustments are very limited. I installed a router in the end of a similar table for a friend. He had this set up exclusively for use with the Oak Park box joint jig; he made a large number of cedar boxes and this was a permanent set up.
Old 07-11-2008, 08:51 PM   #5
mikehop
New Member
Thanks everyone for your responses. I guess using part of this door asa router table is not sensable out so I will consider other alternatives.
Old 07-11-2008, 10:18 PM   #6
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
What you might consider is mounting the router and an insert plate in 3/4" MDF, and mount that into the door.
AxlMyk is offline   Top - Reply with Quote
Garage Door Joinery jimcrockett Table-mounted Routing 10 08-10-2008 11:31 PM
solid oak doors (used) what do you think? reikimaster Tools and Woodworking 8 01-15-2008 03:48 PM
Trying to replicate cabinet door, looking for help AKF Tools and Woodworking 7 12-28-2007 09:44 AM
Kitchen door JEBishop Tools and Woodworking 7 11-02-2007 09:46 AM
Need advice on exterior door making wanart General Routing 15 05-11-2006 12:41 AM
