Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 07-28-2008, 10:48 PM   #1
cbdeajr
New Member
cbdeajr is on a distinguished road
Default Rockler Plate
I just purchased a Rockler plate for my Bosch 1617 router. What size screws do I need to attach the plate to my router? I have to order them as where I live is over 40 miles to the nearest hardware store.
cbdeajr is offline   Top - Reply with Quote
Old 07-28-2008, 11:05 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi cbdeajr
It looks like it takes M4 Pan head screws but they will need to be a bit longer than the stock ones..
BUT I would use Allen Flat Head screws(counter sunk) type..
see manual page below
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-29-2008, 07:42 PM   #3
cbdeajr
New Member
Thanks Router Nut. Save having to order several sizes I don't need.
Old 07-30-2008, 06:31 PM   #4
cbdeajr
New Member
Just got the 4mm but had I check first the Rockler plate is tapped for a standard 10-24 bolt. DUD
Cecil
Old 07-30-2008, 06:48 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI Cecil
But you are bolting the router to the plate , so to say the hole will need to be drilled out so the router can pull up to the plate not the other way around.
Bosch manuals see below
http://www.routerforums.com/bosch/
Cecil
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-30-2008, 08:06 PM   #6
cbdeajr
New Member
HI Cecil
I should have said the router base is also tapped for 10-24's as well as the 4mm. The 4mm is for the base that comes on the router and the 3 that are 10-24 fits the Rockler router plate. The 10-24 are marked on the thumbnail as hole "D"
Cecil
Old 07-30-2008, 08:40 PM   #7
Cassandra
Sr. Member
Cassandra is on a distinguished road
Hi cbdeajr:
The Owner's Manual for the 1617EVS is available online at:
http://mdm.boschwebservices.com/MDMC.../r00073v-1.pdf
According to the section "Use In Router Table" on Page 21 of the manual, the mounting screws are 10-24, as you indicated. (I find this curious as the other screws are metric.)
Cassandra
Cassandra is offline   Top - Reply with Quote
Old 07-31-2008, 12:05 AM   #8
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Yes Cassandra, that is the same PDF file BJ posted the link for in our Router Reference section. There is also an exploded parts view.
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 02:08 PM
Need help with Rockler Aluminum table plate hitnailonhead Table-mounted Routing 8 11-24-2007 01:30 PM
Marvel 40 Router Plate cbsjoez1935 General Routing 0 10-08-2007 02:11 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 11:37 PM
