Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 08-09-2008, 10:05 AM   #1
beemerbob
Dedicated Member
beemerbob is on a distinguished road
Default Cutting Biscuit slots
Got a couple of routers and I can't afford a dedicated biscuit joiner.
Is there an article or a set of procedures that a novice routerer can follow.
Bob from Northwest Florida
beemerbob is offline   Top - Reply with Quote
Old 08-09-2008, 10:33 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi beemerbob
You can do it with your router and a slot cutter or two....and it's very easy to setup and do...
It can be don't on the router table or with a hand router ,with the hand router you will need to make a small jig for the base of the router..
I have a jig made up and if you want to see a snapshot just ask.
http://www.mlcswoodworking.com/shops.../biscuits.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-09-2008, 03:33 PM   #3
beemerbob
Dedicated Member
I'd sure like to see any jigs that you use. thanks
Old 08-09-2008, 04:19 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi beemerbob
Here's a little drawing of one I use now and then...
http://www.routerforums.com/58147-post5.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-17-2008, 08:41 PM   #5
bigjoedo
New Member
bigjoedo is on a distinguished road
BobJ3,
Here is a link to router biscuits and bits that work very well. Even with picture frames.Check "woodhaven".com Hope this helps
Joe
bigjoedo is offline   Top - Reply with Quote
Old 10-20-2008, 10:44 AM   #6
Ted Miller
New Member
First Name: Ted
Ted Miller is on a distinguished road
beemer, I use my router all the time to make slots for biscuits for doing face frame work. I used to use my plate jointer in the past but the last few years I just route one long slot on all my edges then I do have to worry bout where each biscuit will end up. 0's and 10's size biscuits I use the most for 3/4" edges.
I have had the Domino for a few years and this works good as well as just as fast as a long slot cut using the router.
I use the CMT slot cutters, 3/32, 1/8 and 5/32...
Ted Miller is offline   Top - Reply with Quote
Old 10-20-2008, 10:59 PM   #7
Al Killian
Jr. Member
Al Killian is on a distinguished road
I just put marks on the fence showing the start and stop points of the bit.
Al Killian is offline   Top - Reply with Quote
Looking for Jig to Cut Key Slots with Slot Cutting Bit jimcrockett Jigs and Fixtures 8 06-27-2008 09:45 AM
Best Router for Cutting Slots - Slat Wall RAKESS Table-mounted Routing 0 01-27-2008 04:36 PM
Cutting boards for gifts.... gad5264 Project Plans and How To 13 10-19-2007 12:13 PM
cutting slots Grandpasworkshop General Routing 4 10-22-2006 07:59 PM
Cutting slots to overlap plywood panels keylime48 General Routing 4 11-23-2005 11:15 PM
