Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 08-19-2008, 06:26 PM   #1
socalrascal
New Member
socalrascal is on a distinguished road
Default Triton router - bosch table
Hi:
I have the Triton MOF001 2 1/4hp router.
Does anyone know if this is compatible with a Bosch RA1181 benchtop table?
socalrascal is offline   Top - Reply with Quote
Old 08-19-2008, 11:33 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Your router will mount to this table but it is not pre-drilled for it.
Old 08-26-2008, 09:12 AM   #3
socalrascal
New Member
Thanks for the reply Mike. I have ordered a blank aluminum plate from Bosch. When that arrives, I will be able to drill The matching holes for my Triton.
socalrascal
Old 08-26-2008, 04:34 PM   #4
gxbluewave
New Member
gxbluewave is on a distinguished road
Actually the plate that comes with the Bosch table will work with the Triton. You have to use the holes for the 3 1/4 hp PC router. I have this very set up. You will need to drill a hole for the above the table tool. Be sure you orient the router as you want it before you drill the hole as you will see it will not work every way because of the large handles of the router. After that you will absolutely love it though as I do. Good luck.
gxbluewave is offline   Top - Reply with Quote
Old 09-01-2008, 07:43 AM   #5
socalrascal
New Member
Thanks for the info. I'll give that a try.
socalrascal
Old 09-05-2008, 06:06 PM   #6
socalrascal
New Member
You were right. The original plate was easy to set up and drill. No need at all to order
another plate. Thanks for the tip.
socalrascal
Old 09-09-2008, 06:28 AM   #7
gxbluewave
New Member
Thanks - enjoy as this is a great combination!
Old 09-15-2008, 07:34 AM   #8
malb
New Member
malb is on a distinguished road
The Tritons (2400W and 1400W) have some nice features but some can give you minor grief if you aren't aware of them.
They will for instance wind up for above top bit changing, and have an automatic shaft lock so they are single wrench systems. But as a safety feature, this only works with the power switch in the OFF position. With the power switch OFF and the colletabove the table, the switch cannot be turned ON. A few people get caught out when they mount them under the table for the first time, so factor switch access in when deciding on orientation relative to the plate and table.
Also, consult the manual and remove the plunge return spring as it works against the elevating system with the router inverted for table use. It only takes a few minutes to install or remove if you move from under table to handheld or vice versa.
malb is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Triton Router to Bosch Router Table question gxbluewave Introductions 2 12-26-2007 01:32 AM
Triton router to Bosch Table question? gxbluewave Table-mounted Routing 0 12-25-2007 04:19 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
Will Bosch RA1171 table handle 3 1/2 HP router? LBrandt Table-mounted Routing 3 03-25-2007 11:05 PM
