Table-mounted Routing Discussions solely based on operations that are using the table-mounted router. Bob and Rick say "More than 90% of all operations using the router can be done with the table-mounted router.
Thread Tools Display Modes
Old 02-27-2005, 10:44 AM   #1
glassguy1456
New Member
glassguy1456 is on a distinguished road
Send a message via Yahoo to glassguy1456
Default Opening size in router table problem
I have the router workshop table with a phenolic baseplate for the hitachi m12v. My problem is the base-plate is "too large" to fit in the opening in the table. (I can get it to fit if I 'force' it.) I measured the lip that the base plate sits in and found it to be a 'tad' (measurement with rubber ruler!!) under the 3/8 with the 3/8 setup bar on 2 sides. Should this opening be exactly 3/8? I am trying to determine if the baseplate is a little oversize or the opening in the table is a little 'under-size'? If it is the table, should I run around the opening with a 3/8 rabbit bit to try to make it fit or what would you suggest?
I don't want to make mod's to the table and finds other accessories will not work right if the problem is the baseplate.
Thank you and have a good day
Wayne
glassguy1456 is offline   Top - Reply with Quote
Old 02-27-2005, 05:25 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Wayne, the mounting plates are designed to be a very snug fit. You can lightly sand the edges to make it fit correctly. Keep in mind that with use the table opening will wear in a bit, so dont go overboard in making your plate fit. Keep it snug for accuracy.
Old 02-28-2005, 08:09 AM   #3
glassguy1456
New Member
Thanks for the help, I will give that a try. Have a good day
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 07:00 PM
Oak Park Router Table B_Rod Starting Off 27 02-20-2008 07:31 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
I think my old router nearly killed me! peacefrog General Routing 5 09-23-2007 07:11 PM
New poster: Help! Husband wants router for Christmas! Emmie General Routing 21 12-17-2005 09:54 PM
