| Tool Reviews Write up reviews on the tools in your workshop and tell us the positives and negatives. Note: All reviews are required to follow the Tool Review Guidelines. |
| | #11 |
| Retired Moderator Supreme Forum King | The PC is obviously the best deal and I could of gotten a good deal on Bob Noles jig but I will do box joints for the most part. Only occasional use of dove tails.. so that is why the 29.00 price tag looked good but as usual you get what you pay for. Been thinking about taking a class and learning to do DT's the cheap way... by hand Thanks for all the info guys! Corey |
| | #12 |
| Senior Moderator Supreme Forum King | Corey, there is nothing cheap about making dovetails by hand. Your time is worth money. The jigs speed the process saving you more time, so its a trade off.
| | #13 |
| Registered User Forum Fanatic | I just got back from Harbor Freight's sidewalk sale. Took another look at the dovetail jig. The display model had a metal template. I was under the impression it came with a plastic template. For the month of October it's priced at $29.99 (just like the website price) and they were giving out coupons today that would get 10% off a Central Machinery item between Oct 11 and Oct 18. Very tempting... Michael |
| | #14 |
| Forum Contributer Supreme Forum King | Hi Michael WoodStock the Mfg. of the dovetail jigs makes both metal and plastic ones (guides) I like the plastic guides over the Alum.one. because the Alum. are NOT true and hard to fix unlike the plastic ones. If you are going to buy one take a brass guide with you and check the guides out 1st. The guide should go in easy and be true,most use a 7/16" guide but the 1/4 dovetail and the 1/4" slot guides are the ones that are not true and need to be reworked a bit. (5/16" brass guide needed for the 1/4" fixture guide the norm) On the standard 1/2" dovetail guide should be 1/2" but they tell you to use a 7/16" brass guide, guess why. I just gave up and got a dovetail jig from sommerfeldtools.com that works great but it's a bit high in price but it works every time. I just hate to rework equipment/tools to get them to work right. ![]() ---------------------- But I should say for 29.oo bucks it's hard to beat , Just some feed back from one user,,,,One of the plastic cams snapped on the front lock bar, I made a temp one out of Oak, then I send off for a replacement from HF and got it quick at no charge, I also did a bit of tweaking to keep the jig from moving from side to side when I pulled the bar down to hold the stock in place.see the tweak fix on the fourm,all in all it's not to bad and it will make dovetails all day long once you get the hang of it. ![]() http://www.sommerfeldtools.com/products.asp?id=164 Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 10-06-2006 at 05:50 PM. |
| | #15 |
| Registered User Forum Fanatic | I saw that one in the videos Bj, and on the website. It's a great jig and I like the idea of running it on a table but... a little too 'spensive for occassional dovetails. If I buy the HF jig I'll be sure to look over the things you pointed out. thanks, Michael |
| | #16 |
| Registered User New Member | Can the HF jig be modified to make thru dovetails as well? |
| | #17 | |
| Forum Contributer Supreme Forum King | Hi Buck No, sorry to say but they do make jigs like the HF that can but they are not cheap here's just one of them http://www.leighjigs.com/products.php http://www.leighjigs.com/cutters-d16.php# ====== Quote:
| | #18 | |
| Registered User Forum Geek | Quote:
Looking at both jigs and the manuals for them -- I would bet a hamburger they are the same jig. CORRECTION -IF the frames do match -- then yes - you can get a template from Rockler that will make through dovetails. I bought the little blue Rockler jig a few months ago rather than the HF - because I caught it on sale - and because it came with the bit and the bushing - - and because I just plain like the guys at my local Rockler better than the guys at my local HF. I went back about 2 weeks later and bought the through dovetail insert. Of course -- by the time I did this -- I had spent almost as much as I would have spent on a more 'advanced' jig from Rockler or others that came with both inserts out of the box. Live and Learn
__________________ The one who says it can't be done -- Should avoid interrupting the person doing it. Last edited by Drugstore Cowboy; 11-30-2007 at 03:12 PM. | |
| | #19 |
| Forum Moderator Supreme Forum King | They might work. I know the grizzly DTJ is the same as harbor freight. In fact I down loaded the manual from grizzly because the manual didn't really show how to use it from HF.
__________________ Glenmore Days without wood working are days not worth getting up for. |
| Dove tail jig. | Opa | Jigs and Fixtures | 10 | 04-12-2008 11:05 AM |
| Dove tail joint | green15350 | Starting Off | 1 | 11-22-2006 11:02 AM |
| Dove tail jig | fstrange | Jigs and Fixtures | 2 | 01-22-2006 09:43 PM |
| router dove tail jig for table | Paul Shanks | Table-mounted Routing | 2 | 01-14-2006 11:03 AM |
| rockler dove tail jig | reds_21 | Jigs and Fixtures | 2 | 03-06-2005 11:04 AM |
