Help
Go Back   Router Forums > General Woodworking > Tools and Woodworking > Tool Reviews
Steel City 65720 review
This is a discussion on Steel City 65720 review within the Tool Reviews forums, part of the Tools and Woodworking category; I've done a heck of a lot of research in choosing a new table saw. ...
LinkBack (3) Thread Tools Display Modes
Old 04-12-2008, 06:48 AM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
AxlMyk's Avatar
AxlMyk is a name known to allAxlMyk is a name known to all
Default Steel City 65720 review
Report Post Report This Post!
I've done a heck of a lot of research in choosing a new table saw. I scoured the web for reviews on many different brands. After several months, I finally decided on the Steel City 35670 10" Hybred.
http://steelcitytoolworks.com/produc...=12&tool=35670
Steel City also makes the Craftsman 22124 Hybred, but reviews mentioned flex in the cabinet when adjusting the blade angle to the stops. Apparently the metal of the cabinet is a little thinner. Not only that, but a 1 year warranty on the Craftsman as opposed to a 5 year on the Steel City clinched the deal.
I got a couple bodies to help me, hitched up the trailer, and we lit on out to Marsh Power Tools, the local toy store. Got it back to my place and put the steel packing crate in the garage. Removed a few bolts and disengaged the saw from the packing frame. Wound up with lots of boxes of goodies.
Following the order of assembly by the manual went pretty smoothly.
You start by removing the packing from the motor, and installing the belt. A simple task.
Opening the accessories box reveals a bunch of goodies.
Continued-
AxlMyk is offline
Old 04-12-2008, 06:49 AM   #2 (permalink)
AxlMyk's Avatar
You install the dust port, fence hangers, wrench hanger, and the crank handles. Then you move on to the cast iron side tables.
You install them snug, then adjust them level with the main top. This took me an hour or so to do them both.
Next is the riving knife/blade guard assembly.
Continued-
AxlMyk is offline
Old 04-12-2008, 06:50 AM   #3 (permalink)
AxlMyk's Avatar
Checking the arbor for square is next, as well as the 90 and 45 degree blade angles. The arbor was dead on, but I had to adjust the 90 degree blade angle. Very easy to do from the top of the table.
The fence rails are next. The directions could have been a bit clearer here.
Took a while to figure out the placement of the rails.
Aligning the fence was simple. Adjust a couple nylon screws to tighten the fence, and check for parallel with the blade. It was also dead on out of the box. I set the zero on the guide and did a test cut. 4" was exactly 4".
Since I didn't install the outboard table, that will be tomorrows' job.
To be continued.
AxlMyk is offline
Old 04-12-2008, 07:52 AM   #4 (permalink)
BrianS's Avatar
First Name: Brian
BrianS is on a distinguished road
Nice score Mike. Looks like a really nice tool.
Harry will be proud of you with all the pics.
Brian
Brian
A marriage is always made up of two people who are prepared to swear that only the other one snores.
Terry Pratchett
BrianS is offline
Old 04-12-2008, 03:03 PM   #5 (permalink)
AxlMyk's Avatar
Default Finished
Got the mobile base under the saw today, and waxed her up. Nice and shiny, but not so much to reflect light and create problems.
Now for a few comments---
Pros:
*The cabinet is well built and very solid. I notice no flex in it at all.
*The table has a nice semi-polished finish, and is flat within .001".
*When running, you know there is power driving the blade. When turned off it takes approx. 5 seconds for the blade to stop. It is quiet, and has a minimum of vibration.
*The fence is very stiff. It takes quite a bit of pressure to get it to deflect less than 1/16". I got the standard deluxe fence with the saw.
*Alignment of the arbor and fence were right on. Only adjustment I had to do was the 90deg. bevel stop.
*The index magnifier is easy to read and set.
*The blade guard flips up and out of the way for blade changes. It is also easy to remove with one knob.
*There is ample room for your hands to change blades.
*For $899 after the rebate it's a great saw. Even for list price of $999 it's a good deal. Steel City gets good reviews on all it's products.
Cons:
*The miter gauge is junk. I'm glad I have an Osbourne EB-3.
*The saw rocks in the mobile base. I'll have to look into that.
*What is really confusing, 1/4"x20tpi bolts and nuts have a 10mm head. 5/16" bolts and nuts have a 12mm head. Strange having to use metric wrenches to tighten SAE bolts. Allen bolts are the same way, but at least you get the wrenches for them.
*The table insert is not exactly flat. Had a tough time adjusting it flat to the table.
AxlMyk is offline
Old 04-12-2008, 03:13 PM   #6 (permalink)
kp91's Avatar
First Name: Doug
Mike,
I thought the same thing about the miter gage that came with my Craftsman. It looks like they wanted to add every possible feature to a miter gage except for practicality.
The outfeed table could be a little beefier, but it's not that bad....
If your saw is anything like the craftsman, you're going to love it. The ease of putting the blade guard on and off, the quietness of the tool, and quality of cuts are awesome.
Enjoy!
1 John 1:9
http://instaverse.com/
kp91 is offline
Old 04-12-2008, 03:28 PM   #7 (permalink)
AxlMyk's Avatar
Yeah Doug;
They're both nice saws. I'll be building a folding outfeed table for it.
Oh, did I mention that when I was at the toy store, I also bought this?
AxlMyk is offline
Old 04-12-2008, 03:44 PM   #8 (permalink)
challagan's Avatar
challagan is on a distinguished road
Excellent Mike and congrats on the new equipment. I hope to put that planer in the shop later this year. Enjoy it!
corey
P.S. there was a photo of the planer when I posted this
http://iowacarver.tripod.com/
challagan is offline
Old 04-12-2008, 04:14 PM   #9 (permalink)
karateed's Avatar
First Name: Ed
karateed is on a distinguished road
Send a message via MSN to karateed
Hey Mike,
It looks like you've got an 'exceeded data transfer' issue on Geocities....can't see your pics.
Ed......:-)
karateed is offline
Old 04-12-2008, 09:48 PM   #10 (permalink)
AxlMyk's Avatar
Got that problem fixed Ed. Geocities has a maximum per day transfer, unless you pay them money.
Thanks for mentioning it.
AxlMyk is offline
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/tool-reviews/7758-steel-city-65720-review.html
Posted By For Type Date
Table saw questions... - Sawmill Creek This thread Refback 10-10-2009 12:02 PM
table saw quest - Sawmill Creek This thread Refback 03-29-2009 10:53 AM
Top 10 Hybrid Table Saws: Craftsman vs. Grizzly vs. Steel City vs. Jet and MORE! - ToolCrib.com Blog This thread Refback 03-22-2009 09:38 PM
Tool Review Guidelines ~ READ BEFORE POSTING Mark Tool Reviews 1 01-21-2010 08:43 PM
Router review KM12VC reible General Routing 15 11-23-2008 03:40 AM
Steel City Pics AxlMyk AxlMyks' stuff 3 07-18-2008 04:35 PM
Craftsman Fixed and Plunge Base Combo Review..... challagan General Routing 49 01-03-2008 12:06 PM
Stainless Steel Hinge -Sam- Tools and Woodworking 5 10-23-2005 09:40 AM
