Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 03-17-2005, 06:22 PM   #1
ryan.s
Member
ryan.s is on a distinguished road
Default Pipe Clamp question
Hi - I'm somewhat new to woodworking and just started buying the tools needed to get some projects done. I don't know if this is a stupid question or not but what type of pipe is better for a pipe clamp. I just picked up a set of Jorgenson half inch pipe clamps and on the packaging it states to use black pipe. I was thinking wouldn't a galvanized be better or does the zinc coating effect the way the clamp jaws work or does it just not matter. Just wondering why they recommend black pipe. If anyone could clue me it that would be great. Thanks
ryan.s is offline   Top - Reply with Quote
Old 03-17-2005, 06:39 PM   #2
reible
Supreme Forum King
reible's Avatar
Hi,
Just a guess here but black pipe is cheaper......
I have some galvanized on some of my clamps and it works just fine. Black pipe will stain some woods so you wax paper or ???? to keep the pipe from touching the wood (oak I think does this).
Also I think it Rockler has some new zink-plated iron pipe but in 3/4".
Ed
Old 03-17-2005, 06:46 PM   #3
delroy33
Supreme Forum King
delroy33's Avatar
delroy33 will become famous soon enough
i think the main reason is that the galvanize on the pipe is not that uniform in its thickness and could create a holding issue with the clamp plates.
another reason not to use galvinzed pipe is that the clamp platess can cause the galvanize to flake off and cause a safty situiation. (cuts from galvanize flakes)
there is cost issue also. (black cheaper)
3/4" dia. pipe for over 24" long clamping seems to work better.(less pipe deflection)
roy
start square, finish square
delroy33 is offline   Top - Reply with Quote
Old 03-18-2005, 08:37 AM   #4
PoPnBuG
New Member
PoPnBuG's Avatar
PoPnBuG is on a distinguished road
I've used plain old 'black pipe' for years, seems to hold OK for me.
I've not had any staining problems, don't let the pipe touch the wood....
Life's decisions are getting increasingly difficult:
Woodwork, Fish, Shooting? I'm having a crisis!
PoPnBuG is offline   Top - Reply with Quote
Old 03-18-2005, 10:47 AM   #5
dustmaster
Dedicated Member
dustmaster's Avatar
dustmaster is on a distinguished road
I would suggest returning the 1/2 inch and going with 3/4. I had a brutal time trying to keep my wood flat with 1/2 inch pipes. Just too much flex.
dustmaster is offline   Top - Reply with Quote
Old 03-18-2005, 11:47 AM   #6
jerrymayfield
Forum Geek
For years the standard warning was always use black pipe, galvanized isn't consistant, flakes,etc. Gary Rogowski wrote in Fine Woodworking mag. that he has used galv. pipe for over 30yrs with no problems. I know atleast two other woodworkers that use galv. I don't have any pipe clamps,but when i did use them i don't remember any issues with either kind. my advise would be use what ever pipe you want to.
regards
jerry
Old 03-18-2005, 05:03 PM   #7
ryan.s
Member
Thanks for the feedback guys.
Old 03-20-2005, 04:41 PM   #8
semi47
Member
semi47's Avatar
semi47 is on a distinguished road
I use Wrapping paper over my pipes. so that pipes don,t touch the wood or get glue on them.Try to use 3/4 inch pipe has 1/2 inch has to much flex in them hard to hold wood flat.. semi47
semi47 is offline   Top - Reply with Quote
thin wall pvc pipe problem timothy Introductions 6 04-23-2008 12:02 AM
DC Question angus Lobby 3 03-31-2008 08:29 PM
PVC Pipe Holes morbious Tools and Woodworking 3 02-15-2008 05:50 PM
a member of 2 years but never posted a question. Here goes...(PC 695/bosch table) routerron Introductions 4 09-19-2006 12:33 PM
Question About Smoke mblanc General Routing 8 12-17-2005 08:24 AM
