Help
Walker Turner Jointer
This is a discussion on Walker Turner Jointer within the Tools and Woodworking forums, part of the General Woodworking category; All, Thanks to Dad, I have a sorta functional vintage jointer that was built in ...
Old 11-08-2008, 06:13 PM   #1 (permalink)
First Name: Thrifty
Thrifty Tool Guy is on a distinguished road
Default Walker Turner Jointer
Report Post Report This Post!
All,
Thanks to Dad, I have a sorta functional vintage jointer that was built in the days of quality and pride. The sorta qualification applies because the fence has been MIA since before me. In any event, this fine piece of equipment does work pretty well and I can jury-rig crude fences when necessary. However, during Dad's ownership of the piece, I think he mounted a electric motor which seems undersized and too slow. My question to the forum is ........ What is the proper cutting speed for a jointer? I can handle the power issue, but the cutting speed has me a bit baffled.
Thanks,
TTG
Thrifty Tool Guy is offline
Old 11-09-2008, 05:45 AM   #2 (permalink)
harrysin's Avatar
harrysin is just really niceharrysin is just really nice
"I think he mounted a electric motor "
Tell me, was it steam driven before the electric motor?
Harry
The best advice that I can give a newcomer to routing is, learn to use the router mounted, this can be as simple as a board held in a vice, with the router firmly attached and a simple fence held with clamps, and when he/she feels competant and confident in it's use and is familiar with all aspects of safety, THEN, and only then proceed to learn how to use the router hand held. This is MY opinion, and may or may not coincide with that of the forum management, but is based on a lifetime of woodworking.
http://members.dodo.com.au/~sharry02/
harrysin is offline
Old 11-09-2008, 07:35 AM   #3 (permalink)
First Name: Thrifty
Nope, but the family sawmill was.
Harry, you'll have to do better than that!
Old 11-09-2008, 08:46 AM   #4 (permalink)
You might want to check OWWM.com there is a ton of good information about vintage woodworking machines.
Regards
Jerry
jerrymayfield is offline
Old 11-09-2008, 12:49 PM   #5 (permalink)
First Name: Ghyslain
ghyslin is on a distinguished road
the rpm for a jointer should be around 4500
the size of the motor goes with the width of the knives
ghyslin is offline
Old 11-09-2008, 02:19 PM   #6 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Just more info
Jointer speeds
* Re-designed fence system - positive stop @ 45° & 90°
* Heavy-duty cabinet stand
* 1/2" rabbeting capacity
* Depth of cut is 1/2" maximum
* 1 H.P., 110/220V, single phase, ball bearing motor, prewired 110V
* 3-knife ball bearing cutterhead
* Knives are high speed steel
* Precision gib adjustment on dovetailed ways
* Table size: 6" x 47",
* Cutterhead speed: 4800 RPM
* Precision-ground table
* Steel stand has built-in chip chute
* Infeed and outfeed tables have quick-adjustment levers for convenient table height adjustment
* Includes jack-screw and accessory spring kit for setting blades
* Super heavy-duty, center-mounted fence is 4" x 29-1/4"
* Shipping weight approx. 235 lbs.
* Motor: 1.5 HP, 110V, single-phase
* Maximum stock width: 6"
* Maximum depth of cut: 1/8"
* Maximum rabbeting capacity: 1/2"
* Cutterhead: Spiral with indexable carbide inserts
* Cutterhead diameter: 2-1/2"
* Table size: 6" x 46"
* Table height from floor: 32-1/2"
* Fence size: 5"H x 35"L
* Fence adjustment: positive stops @ ± 45° & 90°
* Overall dimensions: 46" L x 27-1/2" W x 37-1/4" H
* Approximate shipping weight: 270 lbs.
* Motor: 2 HP, 110V/220V, single-phase, Magnetic switch is 220V only, TEFC, 3450 RPM
* Precision ground cast iron table
* Cutterhead knives: 4 HSS
* 8" x 3/4" x 1/8"
* Cutterhead speed: 5500 RPM
* Cutterhead diameter: 3-1/16"
* Max. depth of cut: 1/8"
* Max. rabbeting depth: 1/2"
* Cuts per minute: 22,000
* Deluxe cast iron fence size:
* 38"L x 11/4"W x 4"H
* Approx. shipping weight: 480 lbs
Bench Top Jointer ▼
* Motor: 2 HP, 110V, single-phase
* Cast iron table
* Table size: 28-1/2" x 6-1/4"
* Fence size: 4-3/16" x 22-3/4"
* Cutterhead knives: 2
* Cutterhead speed: 10,000 RPM
* Cuts per minute: 20,000
* Infeed table depth of cut gauge
* 45° and 90° fence stops
* Jack screw knife adjustment
* 21/2" dust port
* Approximate shipping weight: 99 lbs.
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 11-09-2008, 03:23 PM   #7 (permalink)
kp91's Avatar
First Name: Doug
I would second Jerry's advice on looking at OWWM. Cutterhead speed could also depend on the type of bearings or bushings installed on the cutterhead.
1 John 1:9
http://instaverse.com/
kp91 is offline
Old 11-09-2008, 05:14 PM   #8 (permalink)
First Name: Thrifty
All,
Thanks for the input. I've briefly checked-out OWWM.com, but didn't dig too deep, so I'm headed back to spend some quality time.
When KP91 mentioned bearings/bushings, I wish I had a means of showing how smooth this jointer cutter head spins. With the v-belt removed from the pulley, the cutter head spins as though there is no bearing friction. Very nice. Admittedly, Dad was a Master Tool & Die Maker and he did have some time to tinker after he retired. Too bad he didn't do a better job at matching the motor and the machine.
TTG
Planer or Jointer angus Tools and Woodworking 10 04-21-2008 09:41 PM
Oak Park Beveled Jointer Jig tpyke Jigs and Fixtures 11 03-27-2008 09:16 PM
Jointer problems Hamlin Tools and Woodworking 5 11-11-2007 03:29 PM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
Another jointer question. ryan.s Tools and Woodworking 10 05-08-2005 11:00 AM
