Help
Rockler Dust Collector
This is a discussion on Rockler Dust Collector within the Tools and Woodworking forums, part of the General Woodworking category; I had a Grizzly G1029Z 2 HP Dust Collector in my old shop, but am ...
Old 12-21-2008, 04:29 PM   #1 (permalink)
First Name: Terry
Terry Pepper is on a distinguished road
Default Rockler Dust Collector
Report Post Report This Post!
I had a Grizzly G1029Z 2 HP Dust Collector in my old shop, but am unable to use it right now due to a lack of 220 volt power in my detached shop, and a likelihood that I will not be able to come up with the $$$ to get 220 out there for some time. With 1550 CFM, the old Grizzly workhorse did a great job.
I am finding that I cannot live without a dust collection system, but don't want to spend an arma and a leg on a 110-volt system, since I will only be using as an interim unit for a couple of years until I can get 220 out to the shop.
I tried hooking up the 2 1/2" hose on my Ridgid 14 Gallon Pro Vac WD1450 to my table saw with a 4" - 2 1/2" reducer, and with only 179 CFM it may as well not be hooked up when it's running.
I have been looking around at 110-volt dust collector possibilities. One of the units I have been looking at online is the Rocker 25344 wall-mounted unit. It claims to pull 650 CFM. My shop is small, with the jointer, router table and planer all on wheels and ganged up in a row along one wall. The table saw is located about six feet from this wall at the center of the run (on the vertical arm of a tee) so were I to mount this little dust collector in the approximate middle of the run, no piece of equipment would be more than six feet away.
My problem is that I have no real way to compare whether this Rockler unit would pull enough in such a set up, since the only prior experience I have is with the old Grizzly G1029Z.
Does anyone here have one of these Rockler units? If so, what do you have it hooked up to, and how satisfied are you with its performance and capacity?
If not the Rockler, does anyone have an alternate 110-volt dust collector with which they are satisfied and might recommend?
I would greatly appreciate any feedback.
Terry Pepper is offline
Old 12-21-2008, 05:40 PM   #2 (permalink)
Hamlin's Avatar
First Name: Ken
Hi,
Have you looked at Harbor Freight? They sell a 2hp 70 gal. unit that works on 110V. The price wasn't too bad last I checked. (That's been awhile).
Ken
"A VETERAN"
Hamlin is offline
Old 12-21-2008, 05:42 PM   #3 (permalink)
nickao65's Avatar
First Name: Nick
nickao65 will become famous soon enough
I think any of the Jet units like the Jet DC 1100 will do the trick.
Jet DC 1100
This one has has remote and timer built in I believe. I have a backup Jet unit I am using now and it works great!
Here is a listing of some different Jet units all would be good as a second unit or sell when your big unit is up and running:
Jet Dust Collectors
nickao65 is offline
Old 12-21-2008, 06:42 PM   #4 (permalink)
bobj3's Avatar
bobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud ofbobj3 has much to be proud of
Hi Terry
Why not just a get a 110/220 volt motor from Grizzy ? or HF
they sale the replacement motors ..
It's just bolts and nuts and about a hour job to replace the motor..
A new plug and a cut of one of one the wires in the cord and your set to run..
Without buying a new dust system
A quick phone call and you could have it on the way...
http://www.grizzly.com/products/1-1-...llector/G1028Z
Description
This large capacity dust collector runs at 110/220 volts giving you the flexibility to run in any shop situation.
A real performer!
* Motor Size: 1-1/2 H.P., single phase, 3450 R.P.M. 110V/220V
* Motor Amp Draw (at 110V/220V): 18 /9
* 6" inlet "Y" with 2 - 4" openings
* Portable Base Size: 21-1/2" x 33-1/2"
* Bag Volume: 5.4 Cubic Feet
* Height (With bags inflated): 78"
* Bag Size (Dia. x depth): 19" x 33" (2)
* Powder coated paint
* Impeller: Balanced Steel, Radial Fin 11"
* Air Suction Capacity: 1300 CFM
* Static Pressure: 10.3
* Standard Bag Filtration: 2.5 Micron
MLCS Instruction Pages & Videos
plus FREE MLCS Project Plans
http://www.mlcswoodworking.com/shops.../instruct.html
Part Finder
find parts for your power tools
http://www.ereplacementparts.com/
Need some help replacing the parts
http://forums.ereplacementparts.com/
Many Router Tips from RWS
http://www.routerworkshop.com/router_tip_glossary.html
http://www.routerforums.com/email-ro...-members-only/
Router Tables ,Ready to use
http://www.rt1000.com/
http://rt1000.com/_wsn/page2.html
Bob J.
Old 12-21-2008, 08:48 PM   #5 (permalink)
First Name: Terry
Thanks for the ideas gentlemen. They are greatly appreciated. I feel so darned dumb for not thinking of re-motoring. I will check that out. Thanks again.
Tags
dust collector, rockler
Dust collector Q New to Wood Table-mounted Routing 5 09-20-2007 11:45 PM
Powermatic Model 73 Dust Collector ryan.s Tools and Woodworking 3 07-19-2006 11:51 AM
I have dust collector info Glenmore Tools and Woodworking 18 03-24-2006 10:09 PM
What dust collector? dustmaster Tools and Woodworking 13 12-29-2004 06:23 PM
