Spots on TS top - Router Forums
 32Likes
post #1 of 36 (permalink) Old 03-18-2017, 12:25 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
Spots on TS top
I've recently noticed several "black spots" (see photos) on the top of my TS. I've always cleaned the top with blade cleaner, coated it with Glidecoat and kept it covered when not in use in a heated shop. These spots just recently appeared on the saw which is about 6 years old. I've never used the table top for any assmbly or finishing.
On discovering these spots I repeated the cleaning using steel wool to scub the spots but nothing seems to change. The spots are not rough in texture nor do the areas apear to be eating into the surface.
Thoughts, comments?
Thanks in advance.
Jon
Jon
JFPNCM is offline
post #2 of 36 (permalink) Old 03-18-2017, 01:04 PM
The problem with using blade cleaner, Jon, is that it'll remove your previously applied protective coating as well as anything else.
Two things you could try: ceramic stove top cleaner, or Autosol. Then paste furniture wax for protection. All those items are inexpensive products.
You'd also need one of those little synthetic pads to apply the ceramic stove top cleaning compound.
I think covering your saw was the culprit; I used to do the same and had the same issue as you. I don't do that anymore.
Danman1957 likes this.
DaninVan is online now
post #3 of 36 (permalink) Old 03-18-2017, 01:57 PM
Jon, I just went out to the shop and tried the ceramic stove top cleaner on some of my darker spots...worked like a charm! Lots of elbow grease as well (unfortunately).
Washed it down with Mineral Spirits, then rewaxed with Carnauba furniture wax.
I was shocked at how much tarnish came off.
post #4 of 36 (permalink) Old 03-18-2017, 02:26 PM
Listen to Dan...
try Distilled White Vinegar on the spots...
make sure you neutralize the DWV w/ baking soda when yur done or thee vinegar will keep on ''cleaning.......
those green scrubby pads will save you a lot of elbow grease...
jj777746 likes this.
Stick486 is offline
post #5 of 36 (permalink) Old 03-18-2017, 02:51 PM
Doesn't distilled white vinegar have water in it?
Herb Stoops is offline
post #6 of 36 (permalink) Old 03-18-2017, 06:26 PM
"Listen to Dan..."
-Stick
I've been telling that to SWMBO for years. Water offa duck's back.
JFPNCM, Nickp, jj777746 and 1 others like this.
post #7 of 36 (permalink) Old 03-18-2017, 09:00 PM
Originally Posted by DaninVan View Post
"Listen to Dan..."
-Stick
put her on the phone... we'll get this issue set right....
Stick486 is offline
post #8 of 36 (permalink) Old 03-18-2017, 09:10 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
@DaninVan
@Stick486
Thank you Dan and Stick for the quick and informative comments. I will proceed and advise. I'm all in for saving "elbow grease" with the little green pads but one has to wonder about
Dan's choice of words "washing it down" when it comes to Mineral Spirits.
Jon
JFPNCM is offline
post #9 of 36 (permalink) Old 03-18-2017, 09:50 PM
Originally Posted by JFPNCM View Post
one has to wonder about Dan's choice of words "washing it down" when it comes to Mineral Spirits.
How so???
it is something it really needs before you wax...
turps, thinner, spirits is the final rise... (what ever is not used and the cheapest..
also they will remove all traces of anything that is on that metal...
Ya know.. you may have to use them to preclean.. I would...
Stick486 is offline
post #10 of 36 (permalink) Old 03-18-2017, 10:15 PM Thread Starter
JFPNCM's Avatar
First Name: Jon
@Stick486
Sorry about that Stick. I was having a bit of fun with the combination of "washing it down" and "spirits" . I understand the intention of the recommendation and agree with that aspect in full.
thomas1389 and jj777746 like this.
Jon
JFPNCM is offline
Human Verification
Favorite beginner base plate? rfsurfer Table-mounted Routing 43 12-31-2013 04:51 PM
Steel City 35990 granite top - setup reikimaster Tools and Woodworking 5 02-21-2012 01:31 PM
remove table top inserts (Red & Grey)from a Freud Table Top kleinj Table-mounted Routing 0 01-04-2012 06:51 PM
router table top issues floridagramps Table-mounted Routing 2 03-29-2010 04:15 PM
Grumble - How to remove snapped screw from router table top? xvimbi Table-mounted Routing 14 02-21-2010 05:04 PM
