Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 04-25-2005, 05:02 PM   #1
rout-on
Dedicated Member
rout-on is on a distinguished road
Default Are there compatable router bases
Hi Y'all;
I have a question for which I cannot find the information myself via the net or Manufacturers website regarding whether I can find a fixed base that is capable of attaching to my plunge router (Craftsman 315.245070).It is a pain in the butt trying to set up using my router in the table with a plunge type base.Any suggestions would be hepful.Thanks.
Can someone move this to General Routing posting section..please
Is my question so far out.......or is it that no one can give me a positive answer.....I suppose that I will have to just go out a buy another router and plate to attach it.I have posted the pic of my router.......it's probably not all that popular,but IT IS the first one I got.
there-compatable-router-bases-clip_image002.jpg  there-compatable-router-bases-craftsman-router.jpg
Last edited by rout-on; 04-27-2005 at 12:20 PM. Reason: Attachment not evident.....where is it
rout-on is offline   Top - Reply with Quote
Old 05-04-2005, 06:24 PM   #2
DONALD
Sr. Member
DONALD is on a distinguished road
I'm not sure I understand your question. Do you have a plunge base router and want to mount a fixed base router to your table? When you bought your router did you get a plunge base only? Most of thodr being sold now come with both bases. If you dont have a Craftsman table insert you'll have to drill the mounting holes your self. Craftsman drilled router plate wont fit any other router I've seen. You can take the springs out of most routers making them easier to use in a table.
DONALD is offline   Top - Reply with Quote
Old 05-04-2005, 07:26 PM   #3
reible
Supreme Forum King
reible's Avatar
Originally Posted by rout-on
Hi Y'all;
I don't know that particular router but it looks like one that would not have a fixed base. You can do a few things to make it easier to use. Some of these things will make it in to a table mounted router and require time to re-assemble for free hand use. As was mentioned the springs maybe removed. This makes it for "table only use" until you put the springs back in but it will make it easier to push up into position and lock. The plastic shield can be removed and that will make changing bits easier to do. These things are "free". If you want to spend money several companies make systems for adjusting the router from above the table.... They start at about $90 and go up to $$$. Of course they have to fit your router???
I started with a Sear router a lot of years ago, I still have it and use it for a few special projects. I also have a "large" Sears plunge router in a Sear table and use to have the springs out but purchased a router razer over the winter. This allows for above the table height adjustments but it was about $90.
Most people find it nice to get a second router.... third router.... forth router...... fifth router...... For about a $100 you can get a major brand one with a fixed base..... if you can spend the money to get a variable speed, softstart one it becomes more useful. If you have a bit more to spend look into one with both fixed and plunge bases.....
If you would like to detail your problems rather then spend the money we might be able to give you more detailed answers........
Ed
Old 05-04-2005, 09:16 PM   #4
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Donald,
I believe Ed and Donald have offered some good advice. Many of us have more than one router and this allows us to leave one in the table without the hassles you describe. I think an additional base will cost little less than an additional router itself if you look around. I myself use the Dewalt 618PK which came with a plunge and fixed base. Fine and well until I saw Norm on TV one day and he had a nice "D" handle base, knowing me, I just had to have one.... $75 plus $15 shipping. A few weeks later I ran up on a fellow on another forum that was selling his "new used only once" DW618 fixed base router for $120 "including" shipping, I did not even have to think about it and grabbed it in a heartbeat. He had to liquidate his shop for personal reasons and was selling everything but the walls. It was as brand new as it could get when I received it.
I say look around for a bargin and get a 2nd router. Mount one in the table and keep the other handy for freehand use. These little buggers are addictive and I just added a PC7310 to my collection after listening to this bunch of router addicts discuss it in another thread and also after researching the model furter from other sources. I saved $30 under retail on ebay of a brand new one.
Just my opinions for what they are worth.
Cheers,
Bob
Bob is offline   Top - Reply with Quote
Old 05-07-2005, 01:22 PM   #5
rout-on
Dedicated Member
Thanks for your responses,///and yes I know that I could remove the springs,I should have mentioned that,but I really don't want to get into that hassle of trying to remove them without having done it before .In regards to purchasing another router,I probably will do that some time down the road..........Incidentally I have built the Norm version router table,not the one he currently uses,constructed mainly of melamine,but the original one,complete with dust collection capability and fence system.......This was all before I realized that I probably would need to buy another router.......Couldn't disappoint the wife...she bought The Craftsman shown in the attachment.Thanks for all the input ...much Appreciated.
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
