Cutting plexiglass - Router Forums
post #1 of 21 (permalink) Old 05-27-2005, 09:34 AM Thread Starter
Cutting plexiglass
Not quite woodworking, but how do you cut plexiglass? Would a jigsaw do it?
Can plexiglass or acrylic be cut on a router? Would that take a special bit?
Drick
Drick is offline
post #2 of 21 (permalink) Old 05-27-2005, 10:51 AM
First Name: Maurice
Send a message via Skype™ to Maurice
You can cut it on your table/radial arm saw with a fine tooth blade or on a band saw.
You can cut lexan this way too
Mo
Maurice is offline
post #3 of 21 (permalink) Old 05-27-2005, 03:27 PM
steveo's Avatar
First Name: Steve
Drick
I had good luck, after trying various blades, by putting in an old dull metal cutting blade in my band saw. Have had decent luck with the router too, slow the speed down to avoid melting the plexi or acrylic material.
Hope this helps........
steveo
steveo is offline
post #4 of 21 (permalink) Old 08-11-2005, 09:58 AM
Suggest a fine tooth band saw blade. Another suggestion leave the backing paper on till completing the cut. Some times helps to use masking tape along the cut line.
Del Delaplante is offline
post #5 of 21 (permalink) Old 08-11-2005, 10:56 AM
Drick, You can get a very clean cut on Plexiglas using your router. No special bit is required. Any single direction saw with fine teeth will cut Plexiglas too. Avoid trying a recipricating blade saw, this will almost always end up cracking your piece.
post #6 of 21 (permalink) Old 08-25-2005, 07:24 PM
First Name: Paul
Just cut some Lexan last night and I used a combination of router, scroll saw and table saw. With the right blades, it cut perfect.
hcbph is offline
post #7 of 21 (permalink) Old 09-01-2005, 12:47 PM
First Name: Danny
I have cut irregular shapes with a scroll saw. If I am cutting rectangular shapes, I just score it with a utility knife and snap it in to. Works for me.
heisnerd is offline
post #8 of 21 (permalink) Old 09-01-2005, 01:46 PM
I asked that question at a woodworking show. The answer I got was to place duct tape on the bottom of the cutline. It keeps the plastic from melting back together. I've done this a lot now on my scrollsaw and with a jig saw. Blade or speed don't matter too much.
dobiepg is offline
post #9 of 21 (permalink) Old 11-12-2007, 09:43 AM
The tablesaw blade that we use at the shop has a negative rake on it to keep from chipping out the plexi. when I am cutting oversize pieces I use a router and a guide.
Use a carbide router bit.
RickWilliams86 is offline
post #10 of 21 (permalink) Old 11-12-2007, 10:01 AM
HI Rick
The one I use is the Freud blade made just for what you want to do...it will come out just like glass
Freud D1080N Diablo 10-Inch 80 Tooth TCG Non-Ferrous Metal and Plastic Cutting Saw Blade with 5/8-Inch Arbor and PermaShield Coatin
http://www.amazon.com/D1080N-Diablo-...883101&sr=1-28
Human Verification
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 07:35 AM
Cutting groove in cutting board Ken Brown Jigs and Fixtures 7 01-06-2010 09:57 AM
cutting plexiglass froglips7846 Introductions 5 04-15-2008 09:54 AM
Cutting Plexiglass Julie Lobby 19 11-12-2007 09:49 AM
Cutting dados on a router table paulcomi Table-mounted Routing 6 08-05-2006 10:52 PM
