| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User New Member | There is no such thing as a stupid question, right? I am trying to make a rabbet cut on one edge of a board. But when I get to the end of the cut, if I keep pressure on the bearing of the bit in order to maintain the width of the cut at the end, I obviously get an ugly rounded rabbet (curved inside) when the bearing reaches the end of the board. Is there some kind simple jig, fixture, router guide, etc. out there that can fix this? Thanks, Bob |
| | #2 |
| Senior Moderator Supreme Forum King | Bob, use a backer board for your cut. This is just a simple piece of scrap wood the same thickness as your workpiece. It only has to be long enough to allow the bit to pass the end of your workpiece before the corner happens.
| | #3 |
| Router King Supreme Forum King | You also can make your board a little longer and then do your routing then trim to size.
__________________ |
| | #4 |
| Registered User New Member | Tack on an extension (backerboard) to your edge, or just route the rabbet prior to cutting to net dim. |
| | #5 |
| Registered User Forum Fanatic | Just use your fence and isolate the bearing. That oughta do it. Mo. |
| | #6 |
| Registered User New Member | Thanks for all of your responses. It's nice to know that I had actually already considered a few of them since they were pretty straightforward, which is something new since often the experts give me complex solutions that I don't understand and/or don't even have the tools for! Thanks again, Bob |
| | #7 |
| Registered User New Member | How about clamping a backer-board on the end? |
| Freud 2200E -- How do I set it up for a measured depth plunge cut? | Ladd | General Routing | 8 | 11-12-2007 04:23 PM |
| Routing a basic rabbet for a picture frame | artframer | General Routing | 62 | 09-04-2007 11:13 AM |
| Sloppy depth settings!! | Birch | General Routing | 4 | 04-06-2007 08:13 AM |
| pc 890 series depth adjustment | rabuckner | General Routing | 4 | 04-10-2005 02:20 PM |
| RouterForums Amateur Night Rabbet bit Tables | reible | General Routing | 1 | 10-10-2004 10:03 PM |
