| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Sr. Member | Can anyone suggest a way to get information on a drill press I just aquired? I have tried searching the web but not much found. It is a 5-speed Chicago drill press, floor standing. Seems to run fine and is built like a tank! Two two guys (beat up old guys) to get it into my little shop!! Would like to get operators manual etc. Was told it is a 70's vintage, but not certain of that.Where else can I look. |
| | #2 |
| Registered User Forum Geek | Hi: Chicago machines are still being built, they are sold by Harbor Frieght. If u have info on the drill press like serial number and or model number ou may be able to get Chicago on the net. You may also locate Harbor frieght on the net and try them, they may be able to direct you to Chicago Machinery. Hope this helps...Woodnut65 |
| | #3 |
| Senior Moderator Supreme Forum King | I think you will find this is a different "Chicago" than the one Harbor freight sells. I have seen this drill press in shops. I will hunt around and see what I can find on parts and manuals.
| | #4 |
| Retired Moderator Forum Geek | I believe the old models of Chicago Drill presses were made in the USA and the Chicago stuff by Harbor Freight now is made in Russia or atleast the ones I have looked at recently. Which are cheaply made. You may have a hard time finding anything on it, you could check at a library.
__________________ Regards Randy PC Support Forums, Free on line virus Scan, The Parasite Fight, Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ |
| | #5 |
| Registered User Sr. Member | Thanks you guys. Was told by prior owner it is "American made" and of 70's vintage (he thought) It certainly seems to be well made and plenty heavy duty. I have figured out how most of the basics work on it. Nice rack and pinion up and down, everything on it is steel-no plastic, no pot metal. I would guess it weighs close to 200lbs. Sure makes nice holes!! Ha! Now I'm still trying to figure out how to make toggle clamps work!! I'm totally embarrassed and humiliated! |
| | #6 | |
| Registered User New Member | Quote:
I actually have one of these Chicago drill presses that you speak of! Actually, I sort of have it indirectly- it was my father's. He would know so much more about it, but unfortunately he passed away this July. It is circa 1970's- probably mid to late 70's. Reason I know this, is that when I was a little girl, the drill press was in my father's gunsmithing shop, in the early 80's. The drill press was near new then, and he was quite happy to have found it. When I got a little older to help out in Dad's shop- that was my drill press to work on. ![]() I agree that it's truly built like a tank- and has withstood moving from 6 different locations of my father's shop as his business grew. I would also be interested in any information you might find on your Chicago Drill Press, because I'm researching values for this piece of equipment for his Estate currently. But I can absolutely confirm, these things are built rock-solid, and are most DEFINITELY not Harbor Freight! ![]() | |
| | #7 |
| Senior Moderator Supreme Forum King | If your drill press is single phase it should be valued around $300-400; if it is 3 phase perhaps a bit less. Older quality machines like this are wonderful for home shops.
| | #8 |
| Registered User New Member | Thank you SO very much, Mike! That is a tremendous help! I believe it is a single phase, so that should help my inventory process much easier! Thank you MILLIONS!!! Angel |
| | #9 |
| Registered User Forum Fanatic | And believe it or not....I am STILL looking for an operators manual. HA!! Mine IS a major piece of gear. There are just a couple little things about it I cannot figure out. Like how do you lock the spindle at a certain height? I see a "fitting" on the L-hand side tha looks almost like it takes a key-is that it? Have changed to a linked belt, checked run-out etc and greased all. A very NICE drill press for what I paid for it and WAY more drill press than I need!! |
| | #10 | |
| Forum Contributer Supreme Forum King | HI Birch The key hole is to remove the harbor/chuck asm. the norm,,, ![]() At one time I had a old drill press that had a set screw on the side of the main body that locked the quill in place but it did go just a bit more with a longer and smaller set screw that would lock the spindle in one spot. You may want to look it over real well..but you're right a manual would be nice. Also check the pull down handle device to see if they have a locking device on it, some have a turn cam that will lock the spindle in one spot.. when they use the press like a mill..but it's only on the hvy.duty drill press the norm. ========= Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 10-21-2008 at 09:33 AM. | |
| Guide Bushing Holes and Drill Press | cbsjoez1935 | Jigs and Fixtures | 2 | 10-08-2007 04:37 PM |
| any fix for a drill press? | rprice54 | Tools and Woodworking | 2 | 11-21-2006 09:33 PM |
| Table Top Drill Press Motor 'Anemia' | jonnyboy63 | Tools and Woodworking | 3 | 03-25-2006 11:43 PM |
| Had my drill press going | Glenmore | Tools and Woodworking | 2 | 08-20-2005 10:07 PM |
| Drill Press | -Sam- | Tools and Woodworking | 18 | 07-24-2005 10:03 PM |
