Originally Posted by VDenchy Ed,
I have found www.routerworld.com and they have Freud slot cutters, 1/16" that cut 9/16" deep in either 1/4 or 1/2 shank, carbide tipped @$16.37. Freud part # 63-100. Also mentioned are bearings, arbors. As I said I am brand new at this so for me to cut these slots in various patterns of wood what would I need? Hope I am not being a pain. Vince |
Vince from the description it sounds like you get the cutter and the arbor and a bearing. Now you have to decide if you want the 1/4" shank or 1/2" shank... this is dependent on the router you get. Some routers come with only a 1/4" collet/chuck while others have both the 1/4" and the 1/2". Some people feel the 1/2" is better but for this bit I don't think it would matter. Now if the 9/16" cut is too deep you could replace the bearing to get closer to the dimension you want.
You will notice that the bit has a diameter listed of 2". As was mentioned you could do this with a hand held router but it might be safer to think about a table where it would be easier to put a guard in place to keep your fingers and other body parts out of harms way. If you click on the oak-park banner that will take you to the place that sells the Router Workshop type tables (some stuff is also on Amazon.com).
Ed
