Help
blade lube
This is a discussion on blade lube within the Tools and Woodworking forums, part of the General Woodworking category; i do alot of re-sawing 8-12 inch boards and i have found this lube Slick ...
Old 04-11-2009, 07:46 PM   #1 (permalink)
Trimax's Avatar
First Name: Curt
Trimax is on a distinguished road
Default blade lube
Report Post Report This Post!
i do alot of re-sawing 8-12 inch boards and i have found this lube Slick Stix to be wonderful Merlube Metal Cutting Lubricants - Lube, Saw, Oil, Coolant - Aluminum Sawing Experts
i use if all the time causes the blade to last longer and and glide thru a cut
if u contact them i think they still send out samples if they dont i really recommend it. Also a (TIP ) i put a coat on the blade if im changing size so it dont rust on the shelf wait to be used again. You dont need to use alot but i put a coat on each time im making a big cut, a stick will last a long time i think its under 4.00
Trimax is offline
Old 05-01-2009, 04:56 PM   #2 (permalink)
dutchman 46's Avatar
First Name: Howard
dutchman 46 is on a distinguished road
Thanks, Is there any problem with paint, or stain after using it?
John 3:16
dutchman 46 is offline
Old 05-01-2009, 07:03 PM   #3 (permalink)
Trimax's Avatar
First Name: Curt
i usually plane the wood down afterward but on the items i have cut for a local craft store paints and stains them has never complained.....send for a free sample and check what your results are. ive been using the lube for a few years now and i really like it
Trimax is offline
Forrestt II thin kerf blade Birch Tools and Woodworking 22 04-11-2009 11:59 AM
10" blade selection?? jeep_man Tools and Woodworking 27 04-10-2009 04:57 PM
"Lo-tech" table saw blade alignment simplenik Tools and Woodworking 4 04-10-2009 12:27 PM
table saw blade selection blurry Tools and Woodworking 19 03-13-2009 12:12 PM
which rip blade to get? rprice54 Tools and Woodworking 11 06-15-2008 06:51 AM
