| This is a discussion on Bandsaw blade problem within the Tools and Woodworking forums, part of the General Woodworking category; Bought a Timberwolf blade 1/4" 10 teeth per inch at Woodcraft for $23.99. Installed it ... |
| | #1 (permalink) | ||
| Registered User ![]() Join Date: Jan 2007 Location: Midwest,Wisconsin First Name: Gary Posts: 226 ![]() |
Bought a Timberwolf blade 1/4" 10 teeth per inch at Woodcraft for $23.99. Installed it on my bandsaw. The problem is that it leaves some really rough cuts on the sides of the wood. It's a low tension silicon carbide blade. You would think this blade would at least leave a smoother cut on the wood. My Craftsman blades with 6 teeth per inch leave smoother cuts on the wood. Anyone have any ideas? Gary | ||
| | #2 (permalink) | ||
| Registered User ![]() Join Date: May 2007 Location: I was born and raised in Holland Michigan First Name: Howard Posts: 1,523 ![]() |
Guess not. You would think that it would be the other way around. Thanks, More room needed upstairs, Too much to remember But i am sorry when ever i forget! ![]()
__________________ John 3:16 Please fill out your profile, It helps us to know you better | ||
| | #3 (permalink) | ||
| Registered User ![]() Join Date: Nov 2006 Location: Fort Worth,Texas USA First Name: George Posts: 2,443 ![]() ![]() ![]() |
The only things I can come up with is either your guides are not adjusted correctly after the blade change or the tension is not set correctly. Did you set the tension as directed on the back of the blade package? If so, other than the guides, I can't think of anything else. I use Timberwolf blades and they work great for me. Oh! One more thing. Is the blade tracking straight?
__________________ George For those who haven't already done so... PLEASE! PLEASE! Fill in your first name and location in your profile. | ||
| | #4 (permalink) | ||
| Registered User ![]() |
You know I have had that same issue. The blade with 10 teeth does not cut near as nice as my blade with 3 teeth. I have no idea why. I can only guess it is a combination of a bad blade and the specific wood being used. | ||
| | #5 (permalink) | ||
I do know that it is best to use a 3 or 4 tpi blade when re-sawing. The reason being that they clear the sawdust out of the cut better thus allowing a faster/smoother cut. Maybe that is the problem. How thick is the piece you are cutting?
| 10" blade selection?? | jeep_man | Tools and Woodworking | 27 | 04-10-2009 04:57 PM |
| table saw blade selection | blurry | Tools and Woodworking | 19 | 03-13-2009 12:12 PM |
| Grizzly GO636X 17" Ultimate Bandsaw | GoonMan | Tool Reviews | 1 | 07-27-2008 02:22 AM |
| Dang Bandsaw Problem | seawolf21 | Tools and Woodworking | 8 | 11-10-2007 04:28 PM |
| Jumpy bandsaw | realsmiley | Tools and Woodworking | 3 | 03-31-2006 02:02 PM |
