| This is a discussion on woodgrain melamine panels within the Tools and Woodworking forums, part of the General Woodworking category; I am going to be building cabinets for my laundry room. I want to make ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I am going to be building cabinets for my laundry room. I want to make the basic box out of melamine panels with a wood grain pattern. The face frames, drawer fronts and doors will be solid wood. I am having a really hard time finding a source for wood grain melamine. HD sells a plain white version, but that is it. I have called a few local cabinet makers and they can't sell to general public. Any ideas out there? I live near Baltimore, Maryland. Thanks for all the good info on this sight. Dennis | ||
| | #2 (permalink) | |||
| Marine Engineer ![]() |
You could always use MDF and then put plastic laminate on the outside of the cabinets and on the shelves where there will be wear. You could then paint the rest of the inside. Just a thought, | |||
| | #3 (permalink) | ||
Any other big-box lumber stores in your area? I bought the wood grain melamine at Menards, a couple of weeks ago. If HD is convenient, you could try the "special order" desk to see if it is available.
__________________ Sawdust is not dirt | ||
| | #4 (permalink) | ||
We have Lowes and HD here and neither can get it. HD does have white. I am trying a local lumber yard that is not part of a big chain. Wish we had a Menards here though. Still searching. . . | ||
| | #5 (permalink) | |||
| Official Greeter ![]() |
I don't know about now, but when I was a project manager for a casework company you could only get melamine in neutral colors ie white, tan and that was about it. Melamine is primarily used as a backer material when P-lam is on the other side. Unless things have changed I don't think you will find it. Best bet is find a Wilson Art of Formica dealer and use vertical grade on the cabinets, and a horizontal grade on counter tops. Quote:
__________________ Wisdom: Where experience and knowledge combine and become one. "We are all one decision away from Stupid!!" Lamentations 3:22-23 "How often we sacrifice the permanent plans of God on the altar of immediate solutions" I have a very good memory, just short is all. | |||
| | #6 (permalink) | ||
We use Dixie Lam thermally fused melamine and have a choice of around 40 wood grain colors and shades. However we also order around 100-500 sheets at a time so I don't know if it's available to the general public. You might call them for a vendor in your area: Dixie LINK This one vendor has some samples on their site, but not sure where they are located: Samples LINK If there is a minimum-quantity order, you probably won't save any money and it would either be cheaper to use Formica hard laminate or maybe use plywood faced with hardwood. (If you've walked into a Starbucks coffee shop, chances are the "wood" displays the packages are sitting on was my project. Not the shelving on the wall, but the in-aisle displays) | ||
| Router for raised panels | Jtomwoods | Table-mounted Routing | 5 | 11-03-2009 07:20 PM |
| Squaring plywood panels | ShaneB | Table-mounted Routing | 46 | 10-14-2009 05:28 PM |
| Is there quick fix for slightly loose fitting raised panels? | tpyke | General Routing | 3 | 02-13-2008 07:59 PM |
| Melamine, Formica, Veneers | mftha | The Finishing Touch | 9 | 04-23-2007 05:33 PM |
| Raised Panels Quick and Easy | bobj3 | Jigs and Fixtures | 2 | 06-03-2006 12:56 PM |
