| This is a discussion on Cutting plastic on a miter saw within the Tools and Woodworking forums, part of the General Woodworking category; I need to cut a black plastic pipe, 3.5" OD with walls 0.25" thick at ... |
| | #1 (permalink) | ||
| Registered User ![]() |
I need to cut a black plastic pipe, 3.5" OD with walls 0.25" thick at right angles. I would like to use my miter saw but am wondering if I can use my existing wood blade (60 teeth) or do I need to spend $130 on a dedicated plastic blade. BTW this likely to be a one-off job and a cost of the new blade is hard to justify. | ||
| | #2 (permalink) | ||
| Retired Moderator ![]() |
Hi, The more teeth a blade has, the better for plastic. But, you said this will be a "one-off" job, you shouldn't have any issues. If you have a band saw, this would work even better. Far better than blades made specifically for plastics.
__________________ Ken ***Please fill in your profile, at least your location. As this will help us help you better.*** "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown | ||
| | #3 (permalink) | ||
ditto on what Hamlin said ...the mite saw may bust the pipe ...or use a hack saw in a miter box | ||
| | #4 (permalink) | ||
| Forum Contributor ![]() |
Turn the blade backward in the miter saw.
__________________ . Never, under any circumstances, combine a sleeping pill and a laxative on the same night. Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ | ||
| | #5 (permalink) | |||
Hi crquack They make a cheap plastic tube cutter just for that job.one or two turns with the plastic tool and it's done, many plumbers use them all the time now days for drain pipe../HD/Lowes/many others... The cheap and easy way, hack saw. ![]() http://www.easy2diy.com/cm/easy/diy_...ge_id=35749959 ======= Quote:
__________________ MLCS Instruction Pages & Videos plus FREE MLCS Project Plans http://www.mlcswoodworking.com/shops.../instruct.html Part Finder find parts for your power tools http://www.ereplacementparts.com/ Need some help replacing the parts http://forums.ereplacementparts.com/ Many Router Tips from RWS http://www.routerworkshop.com/router_tip_glossary.html http://www.routerforums.com/email-ro...-members-only/ Router Tables ,Ready to use http://www.rt1000.com/ http://rt1000.com/_wsn/page2.html Bob J. Last edited by bobj3; 05-16-2009 at 10:48 AM. | |||
| | #6 (permalink) | ||
I've always cut PVC pipe on my miter say. I've gone as large as 2 1/2 in or 3 in. No problem for me. No special blade, just my regular 50 tooth. Vicki | ||
| | #7 (permalink) | ||
Thank you all. Did it with the existing blade. Worked like a charm! | ||
| New router and which starter router bits for my useage? | Skyglider | Router Bits - Types and Usage | 9 | 11-18-2008 03:35 PM |
| Cutting boards for gifts.... | gad5264 | Project Plans and How To | 13 | 10-19-2007 11:13 AM |
| What Router to buy (cutting plastic) | stevegriswold | General Routing | 1 | 07-03-2005 12:56 PM |
